 Whisker pole
Bryan Beamer
Initially Posted - 03/07/2003 :  09:56:05  Show Profile
Steve Steakley or Arlyn,
I'm sure there are others on the forum that use a whisker pole but I can only remember seeing posts from you two guys. I know Steve has the wk and I think a 135% just like I do.
My question; how high up the mast did you mount the pad eye? I have the adj 6-12 hd. & a 135% headsail. I am going to go thru the process of unrolling the sail at the dock and coming up with a height that way. I am looking for a double check before I drill holes in the mast.
Bryan Beamer
<img src="http://im1.shutterfly.com/procserv/47b3dc23b3127cce9462f2858f2b0000001010" border=0>
Daylight Again
C250wk #495
Bill Holcomb
Response Posted - 03/07/2003 :  10:12:49  Show Profile
Hi Bryan,
Because the clew on furling jibs are often cut higher off the deck, you will probably want to eyeball the actual placement of the padeye by unfurling the sail and putting the whisker pole at the clew, then hold the inboard end next to the mast - with the pole horizontal. You might find that you are 4' or more off the deck.
Bill Holcomb - Snickerdoodle #4839
Response Posted - 03/07/2003 :  14:02:09  Show Profile
I would use Bills method to establish the point if your not using a track. I used a short 2 ft track and hit it right about middle but I have a 110. Can give you my numbers...but doubt there good for you.
Arlyn C-250 W/B #224
N/E Texas and Great Lakes
Bryan Beamer
Response Posted - 03/08/2003 :  02:15:02  Show Profile
Thanks guys,
I am going to do what Bill suggested.
Bryan Beamer
Daylight Again
C250wk #495
Tray
Namibia
Response Posted - 03/15/2003 :  09:42:09  Show Profile
Arlyn,
I would love it if you posted your numbers. I too have a 110 and plan on buying a whisker pole.
Thanks.
Tray
C-250WB #554
"Weeny Bean"
Response Posted - 03/15/2003 :  10:11:31  Show Profile
My track is a 2 foot track and measures 25 inches. The bottom is 22.5 inches up from the bottom of the mast. The ring is presently parked at 27.5 inches from the bottom of the mast.
