 Out from Hibernation (1st task)
frich
Initially Posted - 03/09/2003 :  20:39:18  Show Profile  Visit frich's Homepage
Hello to all
It's been a tough winter here on Long Island, but started working on the boat this past weekend. Fisrt order is to re-bed all my handrails, stanchions, and genoa track.
I removed the teak in the cabin exposing the nuts to the genoa track now have to devise a way to work the hardware free from the deck. Has anyone used a stiff spatula for this? Is there a better way, I dont want to damage the topsides.
Appreciate all replies, and by the way santa got me a digital camera so i will post some of the upgrades i did last year.
Frank Rich
84 C25 SK
Response Posted - 03/09/2003 :  21:41:29  Show Profile
Ah yes, the joys of re-bedding.
CB's advice.
I have found a plastic-faced mallet is often useful for working loose bedded hardware. Often some solid raps from different directions will help break things free. Patinence is a virture in this area.
If you're using a screwdriver, putty knife or other prying implement, putting some masking tape down around the work area can help protect the deck from scratches.
If the bedding was done with a strong adhesive/sealant like 5200, careful use of a heat gun can also help. At a specific temperature 5200 releases and turns back to goo. I've also seen chemical 'release agents' for 5200 advertised in the West Marine catalog, but I haven't used any.
'78 Catalina 25
jandrus
Response Posted - 03/11/2003 :  16:43:00  Show Profile
I use a guitar string - really cheap at Walmart or whatever - as a wire saw. Slides right under once the fasteners are out and cuts the fitting free from the deck without damage to either.
Justin
c25 #1942 s/v tako kichi
frich
Response Posted - 03/12/2003 :  19:12:36  Show Profile  Visit frich's Homepage
Justin
Thanks Great tip!!
I will try it this weekend
Frank
Justin
[/quote]
