 Compound and Wax
jefferydfloyd
Initially Posted - 02/06/2016 :  16:08:30  Show Profile  Visit jefferydfloyd's Homepage
This is the third year I have had my 2005 C250. Last year prior to splashing I buffed using Finesse it II and followed with a wax. Prior to that there was minor oxidation. I was very happy with the results.
My question is this. Should I again use the 3M compound and wax, or wax only? There is very little oxidation, but there are a few places that are not as shiny. I am not opposed to buffing again (Makita buffer and the 3M compound ) if it "should" be done, but do not want to waste the time or money if is not needed. It is in a shed now for the winter, so if it is to be done, now is the time.
Since this is my first boat, I am looking for advice from you folks that have been through this many times...
Thanks in advance for your help
Jeff Floyd
TCurran
Response Posted - 02/06/2016 :  20:05:17  Show Profile
Wax, and then go sailing!
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Response Posted - 02/07/2016 :  11:45:45  Show Profile
If its not much oxidation and you just want to bring the shine up again you could use a cleaner wax or just the wax itself. One of those should do it if your using a wheel. Gel coat is very thin so try to avoid the compound if at all possible.
