 Fuel consumption
NCBrew
Initially Posted - 03/29/2016 :  12:27:44  Show Profile
Can anyone tell me the number of gallons a 9.8 HP Nissan burns on a Catalina 25 per hour. Open throttle at about 5 or 6 knots.
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
I spent most of my money on boats and beer, the rest I just wasted.
DavidBuoy
Response Posted - 03/29/2016 :  13:14:09  Show Profile
I think when I clocked mine on a decent trip motoring i was either 1/8 or 1/4 gallon an hour. That's with my 6hp, probably about 4.5kts. Probably was 1/4gal/hr.
Captain Rob & Admiral Alyson
jduck00
Response Posted - 03/29/2016 :  13:36:40  Show Profile
I have an older Yamaha 9.9 high thrust and it burns about 3/4 gallon an hour at 3/4 throttle. I hit 5.5 knots at 3/4 throttle. Not much increase in speed if I open it up.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
cshaw
Response Posted - 03/29/2016 :  17:23:51  Show Profile
I have a Johnson 9.9 on Confetti, and get about the same as you are getting
Chuck
Chuck Shaw
Confetti
Cat 25, hull#1
1976 FK/TR
Response Posted - 03/29/2016 :  18:42:50  Show Profile
"9.8" indicates to me the 4-stroke. I'd say 3/4 GPH is reasonable to expect at a cruising speed of 5 - 5.5 knots. However, you won't really benefit from wide-open throttle. By the time you reach the "theoretical hull-speed" of 6.3 knots for this boat, which should be at less than wide-open throttle, you're causing the stern to squat, drawing a larger wake, and burning way more fuel than the additional half knot or so justifies. You can reach higher than 5.5 knots, but above that your MPG will drop. And that last quarter-or-so of your throttle won't make the boat go any faster (unless a scuzzy bottom has been holding it back).
NCBrew
Response Posted - 03/30/2016 :  00:44:59  Show Profile
Wow! Thats 18 miles per gallon for Davidbuoy and 7.3 MPG for Jduck.
Anyone else with numbers?
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
Response Posted - 03/30/2016 :  04:41:13  Show Profile
I have a 6 hp Nissan 4 cycle engine on my Cal 25, and I haven't carefully checked it's fuel consumption, but I think a fair estimate would be about 1/4 gal per hour. The fuel stinginess of some of the small 4 cycle engines is really remarkable.
DavidBuoy
Response Posted - 03/30/2016 :  04:43:44  Show Profile
I may have done less than 4.5kts but i believe it's close. It was from about a 5 hour sample motoring into the wind. Definitely surprised me as I brought a reserve 5 gal canister in addition to my standard 3 gal and fully expected to use it. Did not end up needing it at all. I could've been running with the tide which would've required less throttle to maintain speed.
Response Posted - 03/30/2016 :  10:16:26  Show Profile
Single-cylinder, 4-stroke, 6hp motors with no alternators definitely can get better mileage than the bigger 8-10 hp twins with alternators--especially at lower speeds. And a 6 can move a C-25, although I'd feel better about being in nasty seas and winds, making 5.5 knots to get to shelter, and maneuvering around a slip with the high-thrust, extra-long Honda 8 I had (the same engine as the current Honda 9.9). It depends on the conditions you expect and the way you plan to use the motor.
Response Posted - 03/30/2016 :  17:01:57  Show Profile
Does that mean you can get 20-25% better mileage by not running the alternator under load? While I don't suggest anybody disconnect their alternator from the battery while the motor is running(which would damage the alternator), you could disconnect the alternator lead before starting the motor. That would mean you'd have to use the pull-start rope to start the engine.
JanS48
Response Posted - 03/31/2016 :  01:35:51  Show Profile
You folks are getting better mileage than I, in the spring and again in the fall I make a 12 mile trek up the bay to the storage yard. My 15 HP Mercury burns 2 gallons on that trip, but it's pushing between 6 ~ 6.3 k at approx. 3/4 throttle.
In reading the other posts, I do notice the stern squat mentioned and a slight mound of water behind the boat.
Reading between the lines, I guess I'd get better mileage holding the speed to a little over 5 k.
82 C25 SR FK
Sailing out of Newport Harbor.
Response Posted - 03/31/2016 :  06:16:49  Show Profile
Yup--at slightly above 6 knots, no matter how hard the engine pushes, the water pushes back just as hard unless you have enough power to get the hull to climb over its bow wave (go partially on plane). I think you'll find 5.5 k to be more efficient and quieter. But is your Merc a 2 or 4 stroke? That also makes a difference. And a 15 is not going to match a 9.9 or 8, which already have some "reserve power"--you have a lot more.
Response Posted - 03/31/2016 :  07:05:27  Show Profile
It has been a while since I checked it, but at about 4.5 kts it was around 3/8 gal/hr (1.5 quarts). I used less than the 3 gallons I bought over the winter. When my son was living at home he once complained that he put more gas in the snowblower than I put in the boat.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
NCBrew
Response Posted - 06/02/2016 :  08:30:59  Show Profile
And Dave 5041 gets 12 MPG?
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
Response Posted - 06/02/2016 :  14:52:30  Show Profile
It is pretty amazing. I fill a 3 gallon tank at the beginning of the season. I fill the second 3 gallon tank when the first gets to about !/2 or I'm leaving on a longer trip. I don't usually buy any more gas unless I motor a lot on a cruise.
DavidBuoy
Response Posted - 06/02/2016 :  16:53:38  Show Profile
So I just took some measurements. After four hours of motoring at 5.5-5.8kts I burned a little under 3/8 gallons an hour. This was pushing pretty hard to avoid a storm into the current and swell. Engine is tohatsu 6hp.
Akenumber
Response Posted - 06/02/2016 :  18:27:39  Show Profile
On a trip from San Diego to oceanside our 8.0 merc 2 stroke used a little over .5g an hour. And that was in rough seas and a stressful trip out of oceanside were I forgot I was wide open for about a half hour. Total of 8 hours motoring. For our next trip I will calculate that .5 and add some reserve. We also have an alternator, not sure it works all that well.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
