 New Name, Strip and Refinshed Wood Trim
Captmorgan
Initially Posted - 05/14/2016 :  17:14:43  Show Profile
Took a lot of work but were no longer Red were green and Now officially the Gal-Way
Only need to do the official ceremony and put on bottom paint.
I used Boat Graphics USA decals for name and shamrock as well as the silhouette of my girls. Made from a photo shopped photo.
The wood was redone with a Sedona oak tint and spar urethane. I know but I don't want to do it every year. Lets see how it lasts. Next up on blocks to do bottom paint and check swing keel cable then the water ! Its a long haul but looking better.
I used some boat cleaner wax and a final coat of airplane and marine wax. nice finish. Not perfect but clean.
"The Gal-Way" 1985 SR/SK Barnegat Bay, NJ
Enjoy Sailing =) Be Safe
Happy Sailing - John
Photo Album
TCurran
Response Posted - 05/14/2016 :  18:39:41  Show Profile
Nice...good job
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Pizza Party
Response Posted - 05/14/2016 :  19:38:59  Show Profile
Your exterior wood looks really good! What kind of shape was it in when you started?
1983 TR FK Dinette C25 on Lake Superior
Response Posted - 05/14/2016 :  20:45:23  Show Profile
Wow! First class! But I'm confused... NJ or VA? Your boat says one, and your signature and profile say another.
Edited by - Stinkpotter on 05/14/2016 20:46:34
Captmorgan
Response Posted - 05/15/2016 :  07:22:45  Show Profile
It was pretty bad, very weathered. In fact some boards were split and I replaced them. Not sure I used the best wood. I replaced both companion way slides. I had some 5/4 rough cut cherry wood and cut and routed them to match shape. then Sealed them in the spar Urethane. I used Helmsman Minwax. Well see how it holds up. I started refinishing the wood on the boat but read a bunch of posts and then pull all the wood and redid it inside. I did one piece one way and that was enough to convince me the lazy way was harder.
The wax was Collinite 925 Fiber glass boat wax, For marine and aeronautical use. I used that after the 3 M cleaner wax.
Photo Album
Captmorgan
Response Posted - 05/15/2016 :  07:42:31  Show Profile
You are very observant, like most sailors. I did the hard part was moved the boat and renamed it. I have left only to change the signature. This actually was not so easy but I did it. Thanks for reminding me.
Photo Album
Response Posted - 05/15/2016 :  07:49:31  Show Profile
Originally posted by Captmorgan
You are very observant, like most sailors...
It's nice to be called a sailor--something I had more of a claim to for the early 55 years or so of my life. Nice reflections on the topsides, by the way...
Edited by - Stinkpotter on 05/15/2016 07:50:32
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 04/09/2017 :  06:46:33  Show Profile
John,
How is the spar urethane holding up?
Seth
"Nomad" 1980 Prindle 16
Response Posted - 04/09/2017 :  13:32:41  Show Profile
I use Minwax Helmsman Urethane on my tiller handle. Every year I sand it down and clean the wood. Unfortunately the coating sometimes cracks and I'll get black marks on the wood. I wish there was a better way. Varnish is nice but it cracks too. Maybe clear coat Cetol??
C25BC
Response Posted - 04/09/2017 :  16:08:37  Show Profile
I took all the exterior teak off my Cat 22 , had it walnut blasted , then 5 coats of Cetol marine natura ,looked pretty good and apparently you just need to coat it once a year on the boat after that , sold it before the first year was up but it still looked like it was just done after 8 months .
Angus
S.V.Tempus
#4748
1984 Catalina 25 SK/SR/Trad.
C25BC
Response Posted - 04/10/2017 :  18:11:14  Show Profile
I've benn looking at Boat Us for new lettering , what size font did you use ?
Angus
S.V.Tempus
#4748
