 bubble on wing keel
dasreboot
Initially Posted - 03/30/2017 :  05:40:34  Show Profile  Visit dasreboot's Homepage
was sanding the bottom yesterday. found a large bubble on top of the wing. I ground it out , and it was filled with a brown powder kind of like dirt or rust. Anyone encounter this?
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 03/30/2017 :  06:24:24  Show Profile
Well it's not rust. The wing keel is lead that is encapsulated with a white colored material.
Edited by - islander on 03/30/2017 06:26:47
oldengineer1949
Response Posted - 03/30/2017 :  07:41:49  Show Profile
scary thought, but how is the bulb attached to the keel stub? Could that bubble be the remains of a rusted bolt top?
Al and Bernadette, "Pualani Nui", '82 C25 SR/SK, homeport MCB Quantico
dasreboot
Response Posted - 03/30/2017 :  08:53:13  Show Profile  Visit dasreboot's Homepage
No, its out near the edge of the wing, unless the wings are bolted onto the center stub and not cast in one piece. it certainly expanded as if it were rust, but yes it is lead, i can see the lead in the bottom of the hole. I'll take a pic this sat. b4 i finish cleaning it out and fill it.
i guess a piece of steel could have been dropped into the cast.
Todd Lewis
Edited by - dasreboot on 03/30/2017 08:54:38
Response Posted - 03/30/2017 :  10:54:34  Show Profile
...somebody's screw driver. (Not worth trying to get it out.)
Response Posted - 03/30/2017 :  17:34:41  Show Profile
Recommend wearing a particle mask or dust mask whenever working with lead. Lead salts are as poisonous as lead, and lead salt dust can easily be inhaled inadvertently.
Edited by - Voyager on 03/30/2017 17:49:43
dasreboot
Response Posted - 03/31/2017 :  05:31:07  Show Profile  Visit dasreboot's Homepage
yes definitely . I wear a paint respirator. I'm also very concerned about all the fiberglass ans paint dust in the air!
Todd Lewis
dasreboot
Response Posted - 04/13/2017 :  05:28:17  Show Profile  Visit dasreboot's Homepage
here is the pic after i cleaned out all the brown dust (silt?). had a fairly large cavity. its filled with epoxy now.
Todd Lewis
Response Posted - 04/13/2017 :  07:08:39  Show Profile
I think you're right about some steel object falling into the mold and rolling into the wing area. When the lead was poured in, the steel floated to the top of the wing and was pushed out toward the edge. The gelcoat-like encapsulation covered it, and then nature had her way.
Edited by - Stinkpotter on 04/13/2017 07:10:22
