 Life lines yes or no
Sailynn
Initially Posted - 08/09/2016 :  19:41:57  Show Profile
Been sailing 30 years plus and never cared for lifelines on smaller boats. I'm a certified keelboat Instructor and am very comfortable on smaller boats. I have two artificial knees and am a well fed skipper. This is our 6th C25 and I am trying to convince my hubby to remove the lifelines like we did on our C22's. He says he can't remember seeing a C25 without lifelines. Does anyone have theirs removed and could you send a picture?
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
Response Posted - 08/10/2016 :  04:37:57  Show Profile
I prefer lifelines generally, but all the Cal 25s in the one design class that I race in have removed them, because they interfere with sail trimming. Lifelines give you one last chance to grab hold of something just before you slide off the foredeck, which can happen more easily on a smaller boat. To compensate for their absence, I require anyone who leaves the cockpit on my boat to be wearing a pfd. Anyone who considers removing them should practice MOB boat handling. As an instructor, I'm sure you're already well-practiced in that regard. I keep an inflatable pfd on board for the foredeck crew to use, in case (s)he doesn't have one, because they're more comfortable and less cumbersome to use.
I didn't remove mine from my Catalina 25, and rarely had much of a problem with them interfering with sail trim, even though I raced it a lot.
Personally, I feel a little nekked and vulnerable on the foredeck of a boat that doesn't have them.
dasreboot
Response Posted - 08/10/2016 :  04:49:13  Show Profile  Visit dasreboot's Homepage
is this your boat?
5696 - Boker Tov, 1987 Standard, Wing Keel
Keith Singer, AZ USA
if it is , you should update the registry
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 08/10/2016 :  04:52:05  Show Profile
I'm with Steve on this one. I raced on a C22 without them and in a good wind I was scared shxtless.
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 08/10/2016 :  07:13:22  Show Profile
Originally posted by Steve Milby
...As an instructor, I'm sure you're already well-practiced in that regard...
...but are your guests well-practiced in case you're the one who goes "Oops!"?
On mine, I could imagine running the lines through the forward two stanchions and anchoring them at the bases of the third stanchions, just forward of the cockpit. The cabintop hand rails are good hand-holds moving forward--forward of those you'd still have the lifelines. (?)
Response Posted - 08/10/2016 :  08:15:33  Show Profile
On a race boat, someone on the crew has basic boat handling skills and could bring the boat around if the skipper fell off. Also, I almost never leave the cockpit when I have crew, and wear a pfd when I do. When I'm racing singlehanded, it's in busy Annapolis harbor, where help is nearby. I don't race the Cal singlehanded in the Bay. Sails on my Cal can be raised, lowered and reefed singlehanded from the cockpit, and I only have to leave the cockpit to furl the mainsail on the boom or to lash down the jib when it's on the deck. I can tether if it's really rough, but I don't race the Cal singlehanded if it's really rough. Those are nominal risks that every singlehander takes.
Why do you want to remove the lifelines? They're seldom in the way on a C25, it would be a lot of work to remove them and plug the bolt holes, and I think eventual knowledgeable buyers would rather have them. I've sailed C25s since about 1979, and have never seen one without lifelines, although it is my vague recollection that they were optional when I ordered mine new in 1980, however I'm not sure of that.
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 08/10/2016 :  18:13:23  Show Profile
It looks great on this Catalina 25: http://www.catalina-capri-25s.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=25069&whichpage=1
I'd remove mine if I didn't have young children that rely upon them. They also help me when carrying a heavy toolbox on and off the boat.
Seth
"Nomad" 1980 Prindle 16
sethp001
Response Posted - 08/10/2016 :  18:15:51  Show Profile
Frank Hopper (handle: pastmember) taught us in another thread some years ago about how to affectively use our lower-height lifelines:
"Plant your food and lift on the life line with your hand!"
I can't find the thread because the search function still doesn't work properly.
Seth
Edited by - sethp001 on 08/11/2016 19:12:48
Response Posted - 08/10/2016 :  18:24:23  Show Profile
Wow, a lot of names from the past on that post. A lot of good people that I guess have moved on.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 08/10/2016 :  19:59:22  Show Profile
Hey, I said that!
Response Posted - 08/10/2016 :  20:03:43  Show Profile
Originally posted by pastmember
Hey, I said that!
No matter who says it, Dave gets credit! What's up with that?
BTW... that procedure definitely works. I've used it more than once to keep from going overboard in Galveston Bay! At least until I got my roller furler. Never been out of the cockpit since. Best purchase I've made.
Speaking of Dave... What is it he always says? "Pull one string, go sailing, pull another string and your done sailing"?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 08/10/2016 20:18:15
Bladeswell
Response Posted - 08/11/2016 :  10:38:42  Show Profile  Visit Bladeswell's Homepage
Hi Lynn,
My boat does not currently have life lines or staunches installed. One of my P.O.s apparently thought it a good idea to remove them. Before I do much more than motor around the bay I will be reinstalling them. Here is a pic as you requested.
Bladeswell
Response Posted - 08/11/2016 :  16:02:30  Show Profile
There has been many posts through the years about falling overboard. Every thing from jack lines to stanchions and lifelines. I am curious as to the reality of it. Not counting those that race or cross oceans, How many of you have actually fallen overboard and did the lifelines actually save you? Falling off the boat at the dock doesn't count either
Response Posted - 08/11/2016 :  17:28:31  Show Profile
Originally posted by islander
Not counting those that race...
Racers' lives matter! An elder racer in my Cal 25 one design racing class fell out of the cockpit and overboard during a race last fall, and the two racers who were leading at the time diverted to pull him out of the Bay. I don't know how it happened, but his boat had no lifelines.
A straw poll like this doesn't tell the whole story with regard to lifelines. You can also grasp them to steady yourself and aid your balance, especially when forward of the grab rails. When the boat is heeling and the decks are wet, you can wedge a foot against a stanchion to keep from sliding off the low side. I've done that many times.
There's really no way you can quantify the number of times one would have fallen off, but for the lifelines and stanchions.
sethp001
Response Posted - 08/11/2016 :  19:13:54  Show Profile
Hey, I said that!
Sorry Frank! I edited my post above to make the correction!
Seth
Response Posted - 08/11/2016 :  20:16:46  Show Profile
Yup--my semi-irregular advertisement for roller-furling and genny-alone sailing.
Sailynn
Response Posted - 08/11/2016 :  21:03:35  Show Profile
thanks for the picture and links. I have roller furling lines, long wooden handrails and a bimini. Lots of things to hang onto so I'm not worried about that. and being a certified sailing instructor all guests and students are required to wear a life vest, even my six lb. dog, if they are outside the cabin. After seeing the pics vs. my c22 it makes the bigger boat look a little naked. Maybe I just need to developed a technique to get around the bimini struts even when they are down. Time will tell. thanks for the comments.
Lynn Buchanan
Sailynn
Nevada City, CA
Response Posted - 08/11/2016 :  22:03:03  Show Profile
More safety never hurts. 'Nuff said.
Sailynn
Response Posted - 08/11/2016 :  23:06:42  Show Profile
Originally posted by dasreboot
is this your boat?
Lynn Buchanan
Sailynn
Nevada City, CA
Sailynn
Response Posted - 08/11/2016 :  23:11:45  Show Profile
I'm already registered. But thanks for the heads up as my profile needed updating. I was the previous owner before Keith and family. They bought a larger boat in Mexico, and we bought the boat back in May 2016 and sail it in CA and trailer it to AZ for Snow-birding.
Lynn Buchanan
Sailynn
Nevada City, CA
Response Posted - 08/12/2016 :  04:07:41  Show Profile  Visit OLarryR's Homepage
I like having the lifelines.
Also, if you do not have lifelines, then where are the birds going to safely perch ?
Larry
Response Posted - 08/12/2016 :  04:19:14  Show Profile
Ha,Ha, Bird perch,yep. They also make for an excellent clothes line.
Bladeswell
Response Posted - 08/12/2016 :  07:44:53  Show Profile  Visit Bladeswell's Homepage
Hi Again,
As I said earlier, my boat does not currently have life lines or stanchions. But I definitely plan on installing them. I know that our boats normally only have one lifeline and our stanchions are 22" tall. I have looked into having them made so that they will take dual line life lines. The cost of the two line stanchions is not much more but the extra life line itself would be nearly $400 more. If I did this, would it be worth it ? I'm also concerned about the ability to pull oneself back on board between the lines if that space goes from 22" to 11".
Bladeswell
Response Posted - 08/12/2016 :  08:36:23  Show Profile
I too like the lifelines and don't intend on removing them but sometimes I question just how safe they are. Think about the damage you could do to yourself if you tripped or slipped and fell directly on top of a stanchion.
Response Posted - 08/12/2016 :  10:01:34  Show Profile
...Think about the damage you could do to yourself if you tripped or slipped and fell directly on top of a stanchion.
Remember the old adage: "One hand for the boat." (...especially on the hard, 8' above the ground!)
Edited by - Stinkpotter on 08/12/2016 10:03:49
Response Posted - 08/13/2016 :  14:50:46  Show Profile
When I was younger I might have said "lifelines? why?" as I age I realize that safety is so important and lifelines are more than essentially important!!! But, you be your own judge . . . .
Peter Bigelow
Rowayton, Ct
