I just wanted to pass along my method of removing the to-hull on my 80 SK. Perhaps it will save you an afternoon beating on the pipe with a sledge hammer.
I took a wooden dowel and trimmed it to fit inside the to-hull pipe hole and gently drove the wood dowel about 1 1/2 inches into the hole. Drive the wood plug, from the exterior of the hull, until it's flush with the hull. Then take a good grade hole saw, attach it to your hand drill and set the pilot hole drill into the center of the wood plug. Drill gently and the plug will act as a guide for the hole saw.
Now just cut out the whole pipe. This leaves a clean hole to drop your new thru-hull into. Then when your done you can get a great look at the old to-hull and perhaps it will look like mine, uncorroded, clean, and would have out lasted me!
I used a small grinder I purchased from Home Depot to do the job. It took just a couple minutes to grind a flat spot large enough to seat the new thru hull bolt. A little 5200 and that's it.
It might have even been Bill Matley's post that lead me to use the dowel method. Only problem I had was I must not have placed the pilot bit dead center as I ended up drilling through the wall of the to-hull pipe most of the way <img src=icon_smile_sad.gif border=0 align=middle> ! I also used a right angle (4.5") grinder to remove the build-up inside the hull - wear a mask! I used Life Caulk, and no, no backing plate here either.
I like your style...the dowel thing that is. I also appreciate your comment regarding the longevity of the to hull. I am a firm believer in the BAROQUE principle in maintenance. Each year I check the to hulls and give them a really good twist, and if they aren't BROKE I don't fix them. I also tie a plug at each fixture. <img src=icon_smile_approve.gif border=0 align=middle>
You're probably right, Mark. I was kinda just heckling <img src=icon_smile_big.gif border=0 align=middle>.
But it's such an easy thing to do, I put backing plates on almost everything that goes through the deck or hull, even if it's just large fender washers for the stuff through the deck.
