 What Size Prop?
Initially Posted - 03/28/2003 :  08:45:53  Show Profile  Visit Champipple's Homepage
Anyone who is using a Nissan or Tohatsu 8 hp motor-
What type of prop did you get?
Response Posted - 03/28/2003 :  09:48:56  Show Profile
Duane, what are your available prop choices for that Nissan ?
(Most small outboards don't have a lot of options available.)
Generally speaking, for a low-speed displacement hull, the prop with the most blades, largest diameter, and lowest pitch is the ticket.
'78 Catalina 25
Response Posted - 03/28/2003 :  10:10:27  Show Profile
Duane - for my Nissan 8 h.p. I had a choice of 3 pitches: 6.5", 7.5" or 8.5". After much discussion with my powerboat friends (yes, I do have 'em!!) I chose the 6.5. It definitely gives more thrust at lower rpm's for when you're manoevring or docking. Running at cruising speed increases the revs by 200 - 300 over the original 7.5" pitch prop (this according to the Nissan factory).
Hope this helps.
Derek
TRFK#2262"This Side Up"
Response Posted - 03/28/2003 :  10:23:05  Show Profile  Visit Champipple's Homepage
Hope this helps.
Derek
it does derek....thank you it is exactly the testimonial I needed.
Response Posted - 04/11/2003 :  08:14:32  Show Profile  Visit Champipple's Homepage
Just Sold the Old Motor on ebay...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2409681872
and Just bought a new Tohatsu 8hp electric start and alternator, 6.5 pitch prop....
http://www.lebombomarine.com/t8.htm
I am sure I will have alternator questions and battery questions for a lot of you as they surface.
RichardG
Response Posted - 04/11/2003 :  10:36:19  Show Profile
Duane:
Nice weight. Nice price too.
Good luck!
Response Posted - 04/11/2003 :  12:00:57  Show Profile
Nice goin' on the 24 year old Johnson($455.00). That new Tohatsu motor sure is light...Is it Helium filled? <img src=icon_smile_wink.gif border=0 align=middle>
North Star SR/FK
Response Posted - 04/11/2003 :  13:17:03  Show Profile  Visit Champipple's Homepage
I don't know, but I will tell you I'm a little worried that the lack of the weight will bring the prop out of the water...we only have a couple of inches to play with.
dw
Response Posted - 04/11/2003 :  19:30:21  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>"...I'm a little worried that the lack of the weight will bring the prop out of the water...we only have a couple of inches to play with."<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I don't think weight is going to have any real effect on whether the motor cavitates or not, because a few pounds doesn't mean much when the 6,000lb, 25ft bronco starts to buck.
If you need a couple of inches, can you lower the bracket on the transom with the extra holes that are provided?
<img src="http://garhauermarine.com/images/product/OB-125.jpg" border=0>
North Star SR/FK
Response Posted - 04/11/2003 :  22:28:57  Show Profile
I noticed that Tohatsu offers an extra-long (25") shaft in the 9.8 hp model.. and it's about the same weight. For someone who's venue will inlude some ocean time, that long shaft is pretty attractive... and my back would appreciate the light weight.
Then I see it's a 2 stroke and I can't buy one in California anyway... oh well.
'78 Catalina 25
RichardG
Response Posted - 04/12/2003 :  12:11:13  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I can't buy one in California anyway... oh well<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Just take a short drive to Oregon (plus no sales tax) or Nevada.
Response Posted - 04/15/2003 :  08:28:20  Show Profile  Visit Champipple's Homepage
North Star SR/FK
No don trust me - its weight.....
The Cavitation isn't the issue...Motor mount is as low as it will go.
Edited by - Duane Wolff on 04/16/2003 14:05:45
RichardG
Response Posted - 04/21/2003 :  10:55:40  Show Profile
Duane:
What's the measured shaft length of your new long shaft motor, based on the 'regular' definition of shaft length (cavitation plate to top of motor mounting board)? After hearing that Tohatsu/Nissan specs use a different definition, I measured a motor at Boaters World (they only had standard shaft motors in stock) based on the regular shaft length definition -- I got 17 1/2".
Response Posted - 04/21/2003 :  14:32:54  Show Profile  Visit Champipple's Homepage
Duane:
Here is the story - about two years ago, we replaced the mounting bracket with a Garelick. Do to the mounting and the travel on the bracket, we had about 1" of water above the skeg. I should note that the bracket isn't going any farther down...we are out of room.For the most part we were fine with that.
Prior to last season, we had no idea that there was about 4 inches of water under the cabin sole...(long story, problem is fixed, water is gone, for additional info look for my posts on mast compression posts) The removal of this water, along with a few other things raised the boat a bit. The old Johnson 9.9 measured 22 inches from skeg to the bottom of the bracket. We corrected this by filling the water tank (which we never did before), moving the anchor aft into the sail locker and moving the back up anchor under the quarterberth. That just about go us our inch back.
The Tohatsu measures 23" for the long shaft (same area) however only weights 75 lbs for the long shaft(I didn't check the exact weight so don't kill me if I am off a few , you'll get the idea in a moment) It also only comes with a 3 gallon tank. So if you look at the weight of 3 less gallons of gas and the 30+ lb difference in the weight of the motor I am hoping I still have a prop in the water...Otherwise its a new mounting bracket
