 Sail Trim in High Winds
Alan Therrien
Initially Posted - 11/25/2001 :  18:08:47  Show Profile
My last sail this season was in 25 knt winds with gusts up to 30 knts. The trip out to the ocean was quick and uneventful. I was double reefed, and had a few wraps taken in on the furler.
The return trip was another story. The wind shifted before
Steve Raffel
Response Posted - 11/26/2001 :  11:25:45  Show Profile
It sounds to me like you did the right thing. I would have started the motor. If you were over 30 degrees, more sail was not the answer.
Steve Raffel
C 250 WK # 408
tinob
Response Posted - 11/26/2001 :  15:01:43  Show Profile
Alan,
I agree with Steve you needed more push, adding the motor to the sail plan would have helped.
Val
Val Bisagni
Alan Therrien
Response Posted - 11/26/2001 :  17:33:41  Show Profile
Thanks for the confirmation. I did use the Evinrude 9.9 on some of the port tacks. The prop was completely out of the water on the starboard tack. And the motor alone was not enough to make forward progress. Sometimes I guess you just have to do it th
Douglas
Response Posted - 11/26/2001 :  22:05:48  Show Profile  Visit Douglas's Homepage
Havent been out on a C250 but I did experiance the same conditions in my C25. Down to a double reefed main and motor no head sail.
cathluk
Response Posted - 11/27/2001 :  08:45:49  Show Profile
The double reef was definitely the right call! I might have pulled more of the jib in if the angle of heel was too extreme - you'd be surprised what a difference that makes!
Which brings up another question - when the boat is heeling excessively whe
Response Posted - 11/27/2001 :  11:46:27  Show Profile
I agree with the other folk's suggestions, but beating to windward in high winds and choppy seas is very uncomfortable and hard on the boat. Reaching or running is much easier on both boat and crew.
Sometimes people are so determined to follow their i
MarkTM
Response Posted - 11/27/2001 :  12:38:13  Show Profile  Visit MarkTM's Homepage
Which brings up another question - when the boat is heeling excessively where do you brace if you are too short to reach the opposite bench w
Response Posted - 11/27/2001 :  14:47:55  Show Profile
<b><i><font color=blue><h4>Alan, my additions would be fall off a bit prior to making a tack to gain more speed to carry the tack thru and then make a smart turn.
Also, in a breeze the forestay needs to be tight if running headsail to avoid pocketing
cathluk
Response Posted - 11/28/2001 :  08:14:03  Show Profile
Mark -
I should have been more clear in my question. Yes, when at the helm I brace myself quite nicely with the pedstel, also tend to be on the seats and not sitting on the rail. My questions was more for when my husband refuses to relinquish the hel
MarkTM
Response Posted - 11/28/2001 :  09:21:26  Show Profile  Visit MarkTM's Homepage
My questions was more for when my husband refuses to relinquish the helm after pulling out of the slip ('cause he knows he won't usually get
Alan Therrien
Response Posted - 11/30/2001 :  09:46:05  Show Profile
I was standing behind the wheel with my feet spread VERY far apart. My wife was initially sitting in the companionway, but as the wind picked up she had all 5'3" braced against the leeward side of the boat - not a comfortable position.
<BLOCKQUOTE id=qu
Alan Therrien
Response Posted - 11/30/2001 :  10:06:38  Show Profile
Thanks to all for your valued advice. I think a bit more twist with less headsail and more motor would have made a big difference.
My Evinrude is an extra long shaft, but still wouldn't stay in the water on the starboard tack. I had considered anot
Ben - FL
Response Posted - 12/01/2001 :  22:11:55  Show Profile  Visit Ben - FL's Homepage
In response to Steve Milby I like to mention Sail Magazine had an article "Last Call Before the Bar Closes" (or something like that).
The article mentions a lot of the stuff covered here about making a pass in hard weather. It was last months issue or
