 Cdi Furler with bow roller
stang9150
Initially Posted - 01/24/2021 :  19:46:57  Show Profile
Is there a way to make the bow roller work with a cdi furler? I have the roller from catalina direct, this is the one with the stem and roller together. My delta anchor will not clear the drum. So options are to mod the roller and extended it out, somehow maybe raise the roller drum, or look at different anchors. Any thoughts? Thanks
Response Posted - 01/25/2021 :  06:26:00  Show Profile
The easiest would be to try a different style of anchor and see how that works. You could try a fluke for example. See if you can borrow one to try out for fit. Moving the stem fitting farther out will just move the CDI drum out with it. Possibly you could raise the drum and furler with a toggle?
Response Posted - 01/25/2021 :  17:23:30  Show Profile
CDI furler with bow roller and Fortress Guardian anchor, photo is about the 21'st post in:
http://www.catalina-capri-25s.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=21690&SearchTerms=roller
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
AUAE
Response Posted - 01/31/2021 :  22:52:43  Show Profile
I added a toggle to raise the drum. I had room to add one toggle (1.25") without raising the furler top fitting too far up the forestay and without modifying the furler (CDI FF6). It's still a crowded area with the anchor roller, bow pulpit, and furler drum, but I feel like I'm less likely to hit the drum with the anchor.
Kav Eldredge
1990 TR/WK #6001 "Ocean Liner"
Birmingham, AL
