 6hp 4 stroke on a C-25?
dave andersen
Initially Posted - 12/01/2001 :  14:38:07  Show Profile
California has outlawed sales of new 2 strokes as of Jan 1, 2002.
West Marine as of now is only selling 4 strokes. The 6hp Mercury
(same as the Nissan, I understand) 4 stroke weighs in at 55.4 lbs.
They no longer make an 8hp. The next step up is a 9.9
Bristle
Response Posted - 12/01/2001 :  19:04:23  Show Profile
Hi Dave... You're right to wonder about your bracket for a 4-stroke. Not only does it weigh more, but the new ones have high-thrust props and gearing that increase the stresses to those of a 2-stroke with almost twice the power.
The problem I see wit
dave andersen
Response Posted - 12/01/2001 :  19:59:53  Show Profile
Thanks, Dave B. But Merc does have a long shaft for the 6hp
4 stroke -- again it is half the weight of the 9.9. I'm concerned
about having enough power left over for heavy seas. I know it will
push it a hull speed with ease in good seas.
Ironlegs
Response Posted - 12/01/2001 :  20:15:28  Show Profile
I got a long-shaft Merc 9.9/4-stroke for Paloma, my C25 swing keel and I like it. I'm 61 & pretty strong, but gratefully accepted a helping hand mounting it on the transom mainly due to the awkwardness factor. I added a couple of rubber bungees to the spr
BCain
Response Posted - 12/01/2001 :  20:16:18  Show Profile
Dave, I have a 6hp 2 stroke on Wind Shadow and while it will push her at 5 knots it has no reserve if the wind picks up or I get into a current. Try for at least 8hp or better.
Mike Vaccaro
Response Posted - 12/01/2001 :  20:40:33  Show Profile
Dave,
Use a 2000 6HP Johnson on our boat with no problems. Will move her along at hull speed with the high-thrust prop we installed. The Johnson 6 HP and 8 HP are the same motor, save for the RPM at which they run. A motor will only produce rated h
Bristle
Response Posted - 12/01/2001 :  22:01:10  Show Profile
4 stroke...
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Ver
Douglas
Response Posted - 12/02/2001 :  12:37:00  Show Profile  Visit Douglas's Homepage
Having sailed the San Juan Islands this past year with a 8Hp Honda I would say No the 6 would be to small. I do have the original two armed outboard mount. After having the spring break on the mount while in the islands I rigged a small block and tackle t
Gary B.
Response Posted - 12/02/2001 :  20:12:46  Show Profile
I have posted before that I have a Yamaha 9.9 four stroke electric start that I like...a lot. It weighs over 100lbs. Honestly, it is probably MORE power than I need: 7+ knots at full throttle, which is rare, but 6.3 knots at a little over 1/2 throttle,
walkerman
Response Posted - 12/03/2001 :  23:52:30  Show Profile
Hi:
Two cents from a newbie.
I have a 5 hp Nissan 4-stroke long shaft on my 1984 Fin Keel C-25.
I don't have enough experience to comment, other than to say that I have motored for several hours, even in heavy chop and unfavorable current and have alwa
RichardG
Response Posted - 12/04/2001 :  15:38:46  Show Profile
Dave:
My 1985 Suzuki 6 hp is like the Energizer Bunny -- it keeps going and going and going...
Despite the other responses in this thread, I and many others around me feel a 6 hp is sufficient for a boat this size. As a reference, I regularly sail
