as i sit on the beaches in destin for a week i started to think of all the projects for my catalina 25 next year. i went to west marine and got a switch for adding a second battery. i have an electric start that i will also want to add to the switch do
The West Marine catalog had a "West Advisor" on this topic. You can probably get the same info (and an exact diagram) from their web site. Their solution is very good: "A" battery is exclusively for the starter and "B" for the cabin service and a simple
The Battery switch (a-b, a , b or off) works fine with for selecting which battery you wish to use. There are a bunch of electrical engineers on this board and since I don't want to make a mistake I will leave responee this simple and let them fi
The main problem with the A-B-Off-Both switch is that you can easily destroy expensive onboard electronics with the switch set incorrectly. Here's part of what West Marine says about it (see their web site for the rest)...
Without an A-B switch, how do you charge either or both batteries--for example, off the outboard alternator? Is it best just to switch to parallel for charging?
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Without an A-B switch, how do you charge either or both batteries--for example, off the outboard alternator? Is it best just to switch to pa
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> The main problem with the A-B-Off-Both switch is that you can easily destroy expensive onboard electronics with the switch set incorrectly.
"Your "ideal" system may or may not require all of these components. What's important is that the total system meets your daily electrical needs with sufficient battery capacity and charging ability.
I know this is useless without specific information but unless I misread the instructions on my battery charger it states both batteries must be charged at once with the selector on both. Charging only one would damage the charger....I've got to dig th
Perhaps some civic minded electrical engineer on the forum could use their lunch break to sketch out the exact circuit (maybe one using the A-B-Off-Both switch and another using the West 3-switch plan) that included...
I have a bit more basic question: What is everyone running that requires two batteries? We liberally run lights, VHF, and wind/depth gauges and the battery can easily do a 14 day trip without a charge. Also, where is that second battery stored?
Doug. You are obviously the self assured..nothing can go wrong type. I like the 2nd battery so I can run my lights, radio ect. without the danger of running the battery down and not being able to use my electric starter. I know it starts with the pull
For Andy P., who asked: <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>... use their lunch break to sketch out the exact circuit (maybe one using the A-B-Off-Both switch and another using
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I have a bit more basic question: What is everyone running that requires two batteries? We liberally run lights, VHF, and wind/depth gauges a
