Now in my second year of piloting our 86 SK, I am thinking of rigging a topping lift to assist when reefing. I have kept my eye on other set-ups for ideas, but would really appreciate the great comments from this group. I would like to go with 1/16" stain
<font face='Comic Sans MS'><font size=2>Todd – I simply mounted a shackle on the back side of the mast head casing (there should be a pin there) with a small block. I used ¼” line from the back of the boom up through the block, back down to the deck where
Todd - I'm with John G. on this one! Definitely use line rather than a wire - it also saves weight aloft! I used 3/16" yacht braid from the masthead shackle, directly down to a V-jam small fiddle block on the end of the boom, thus allowing me to raise/lo
I also agree. Line not cable. I would also recomend if your going to drop the mast that all halyards be converted to line. The sheaves are only 12$. You can swap the lines end for end to prevent wear. The best thing though is you can use the halyards to l
Todd, I use the 1/16" vinyl coated ss cable, cut 2 feet short of the boom with a 1/4" dacron pig tail on the end to use with an adjusting tackle on the end of the boom. The 1/16" cable is a lot less windage aloft. The mast head end is on the same clevi
