Finally splash down!! However over the winter i changed my swing keel cable, and was unable to test lowering the wich since i was on chocks. In my haste to get her in I forgot to test her when she was hoisted. At my slip i tried raising the keel and it seemed to work fine. But when i go to lower it it turns maybe a 1/4 turn and then it is as if the clutch is not grabbing. I can turn the handle freely but the winch drum does not turn.
Could this be that the keel is hitting bottom and there is no longer weight on the cable? I would think that i would see slack in the cable but i see nothing. Any help is appreciated.
By the way good/ safe sailing to all on this site who have aided me in the 2 years I am here.
If you don't get new winch cable spooled on tightly and evenly enough, the outer wrap can dive under the others and get bound up when it is loaded. If trapped badly enough, it won't spool off.
Don't know if that's the case in your current dilemma, but it might be worth a look. If this has happened, you'll need to find a way to 'unload' the keel to release tension on the cable, perhaps by passing a strap under the boat from winch to winch. Then you can get the cable worked free.
Be extremely careful, the keel has a tremendous amount of stored energy in the up position. You could lose a finger or do serious damage if it got away from you. Might be best to get the boat back on the trailer to work on it.
Currently maintaining two holes in the water...'77 Venture 23 and new to the family, '78 Catalina 25
Sounds like you've either bound the cable on the winch as "Clam" mentioned, your clutch is slipping, or probably a combination of the two. Doesn't sound like you've dropped your keel fully with only a 1/4 turn.(usually takes 27-28 turns)
You're right, You can tell if the keel is fully extended by testing the tension of the cable. With most swing keels, you can release extra cable after the keel has hit it's stopping point and the cable will be slack (and will not hum when under way).
If is is jammed/bound you may need to work it loose, hard to do in the water when you can't jack up the keel manually to give yourself some slack.
I second Roof's recommendation to replace your winch. I too replaced mine during the last offseason and couldn't be happier. I now always know where my keel is and have more confidence. Be warned though, the bolt holes in the mounting plate didn't line up with the existing holes and I had to drill new ones (in the winch). I also had to buy a new handle as the old style would not work with the new winch.
The winch does click when raising the keel, I will check today to see that the cable is not bound. The winch was working fine prior to the cable replacement.
Loading the winch is one of those things were you really need two people... one pulling on the winch cable as hard as they can while the other cranks and spools the cable on.
Alternative is to rig something up to hold tension... must ponder this as I need to spool new cable myself.
Thanks for the help, i should have looked a little more carefully and not panic. It was the wire cable clamp nut hanging up on the winch housing causing it to disengage the clutch.
Now all I need is te weather here in NY to get better, Can anyone help with that<img src=icon_smile.gif border=0 align=middle>
