 small crack in rudder paint
bsmudd
Initially Posted - 06/02/2003 :  19:07:18  Show Profile
My rudder, centered on the edge facing behind the boat, has a thin vertical crack about ten inches long, and starting 6 inches above the waterline. It appears that it may be just the paint which has opened up. Can I just paint this crack or is there a possibility of internal water damage?
Response Posted - 06/03/2003 :  00:17:26  Show Profile
Unfortunately, the paint is probably opening up because the surface underneath is expanding due to delamination.
I'd get it dried out and apply some thin, penetrating epoxy like WEST system into the crack until it refuses to accept any more.
Sounds like you're catching it early.
'78 Catalina 25
Response Posted - 06/03/2003 :  15:29:22  Show Profile
Congrats! You have the Catlaina Crack. You may want to open this up before filling to allow it to dry out.
I opened this crack by running it (lengthwise) over my table saw. Filled with a mixture of epoxy/filler, re-gel coated. No probems since.
Others have suggested storing your rudder indoors in the off season so any remaining moisture doesn't freeze and expand.
Good luck.
Steve Shetter
Response Posted - 06/03/2003 :  16:15:22  Show Profile
I have just had my rudder repaired. It had the same problems that you have mentioned, but mine were MUCH worse. I thought about buying a new one, but the repair was somewhat cheaper and I'm glad I did it this way. My rudder had air dried for several months and the boat builder clamped it tight, reglassed and gel-coated to my color specs and it looks like a new one. In fact, I just rolled the last coat of bottom paint on it this morning and she goes into the lake in about 2-3 weeks.
Steve Shetter
"At Last"
#2381
bsmudd
Response Posted - 06/03/2003 :  17:09:38  Show Profile
The Catalina Crack. That's catchy, and if i didn't have to fix it I might be proud of it.
So, OJ, when you ran it through the table saw, you were just trying to open it up a little to get the epoxy in there and remove some wet material?? What type of blade on the saw?
Response Posted - 06/03/2003 :  22:28:20  Show Profile
<font color=blue>Exactly</font id=blue>
<font color=blue>Well, I'm embarassed to admit I was too lazy to change the blade for such a short cut . . . 80 tooth carbide tip. I also wanted to achieve a smooth, clean cut. How's that for justification <img src=icon_smile_wink.gif border=0 align=middle> ?
I then nosed around with a dremel tool and opened up some voids exposed by the saw cut. Felt like I was performing a root canal.</font id=blue>
Edited by - OJ on 06/03/2003 22:31:01
Dave B
Mali
Response Posted - 06/03/2003 :  22:39:07  Show Profile
bs... Where do you live? Has the rudder been in freezing weather (such as when stored during the winter)? Moisture can enter at the hole for the tiller, get into the plywood core, and then expand when it freezes. On top of everything else, If you're up north, I suggest storing it inside during the winter.
bsmudd
Response Posted - 06/04/2003 :  00:48:50  Show Profile
My boat's in Annapolis, so it definitely sees some freezing temps throughout the winter.
I'm going to follow the advice you all have given me, but one more question. Why does this quote from the 1988 Owner's manual makes it seem like the rudder core can't be affected by water?
3.4.2 CARE AND MAINTENANCE OF YOUR RUDDER:
Your boat has been equipped with a composite urethane rudder.
The rudder is composed of a rigid. closed-cell urethane core with
a fiberglass coating. Water, diesel. solvents or marine borers
will not damage your rudder blade even if the glass coating has
been damaged.
Closed-cell plastics can be damaged by heat. To eliminate the
risk of damage, rudders should be sheltered from the sun with a
white wrapping when the boat is out of the water. Composite rudders
should never be painted black.
- B.S. Mudd -
on the Chimera
Response Posted - 06/04/2003 :  16:50:21  Show Profile
. . . but one more question. Why does this quote from the 1988 Owner's manual makes it seem like the rudder core can't be affected by water?
. . . Water, diesel. solvents or marine borers
been damaged.
The answer should be quite obvious my dear Mr. Mudd; the above had to be written by a sales and/or marketing person, not an engineer . . . <img src=icon_smile_wink.gif border=0 align=middle>
