 Boom set - any ideas?
Headhunter
Initially Posted - 06/12/2003 :  09:42:42  Show Profile
Having some new sails made. My sailmaker suggests that the sail will/would be much more efficient if I set the boom. With my tall rig, he suggests that the top of the boom should be 28'1" down from full hoist on the mast. My question is, what would be the best way to bolt the gooseneck into the mast slot?
Response Posted - 06/12/2003 :  10:15:55  Show Profile
Why does he think it would be more effecient?
Some folks go to a lot of trouble to get a sliding gooseneck.
The sliding gooseneck allows you to set the boom at whatever position you choose. Make a mark on the mast 28'-1" down from the top and set the boom there with track stops and/or cunningham.
'78 Catalina 25
Headhunter
Response Posted - 06/12/2003 :  11:33:04  Show Profile
As I recall from race weeks at Key West, Tampa, Charleston, etc. it seems that most of the true racers - the Mumms the Melgeses, etc. had/have fixed booms.
This sailmaker makes sails for a lot of the NCYA, SCYA, SAYRA, and Key West Race Week winners. He supposedly knows how to make a boat go fast, which is what I am looking for.
Do you think that the desireability of the sliding gooseneck is because of it efficiency or more because it's nice to be able to raise the boom to get it out of the way for dining, etc.? Other opinions? This warrants some research.
I am intrigued by the idea of a "cunningham" to pull the boom down to the desired level, but would think, and I was wrong that one other time, that downhaul tension directly on the boom would affect other aspects of sail shape than just the luff tension. A properly attached cunningham puts no pressure on the boom itself.
Doug Riley
"Life o' Riley"
5231 '86 TM FK
Lake Norman, NC
Response Posted - 06/12/2003 :  11:47:31  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I am intrigued by the idea of a "cunningham" to pull the boom down to the desired level, but would think...that downhaul tension directly on the boom would affect other aspects of sail shape than just the luff tension. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
The cunningham doesn't exert any forces on the boom, only on the luff of the sail.
As for fixing the boom to the mast, as Bruce stated, sail track stops can be used to fix the boom at a certain location on the mast. I have a slide stop both above and below the gooseneck to keep it pretty much in one spot on the mast.
<img src="http://www.sailnet.com/store/prodimage/160x160/dav2350.gif" border=0>
North Star SR/FK
Edited by - dlucier on 06/12/2003 11:54:00
Headhunter
Response Posted - 06/12/2003 :  11:52:29  Show Profile
Is this a track stop similat to the pop-top holder in the lower part of the mast slot? You've probably got something a bit stronger than that, right?
Response Posted - 06/12/2003 :  12:00:43  Show Profile
I use two of these to hold the gooseneck in place. My boom is positioned so when the main is at maximum hoist and with no cunningham tension, the luff is rather loose(for sailing in light air). When the wind freshens up, I tension the cunningham to tighten the luff and trim the main.
North Star SR/FK
Headhunter
Response Posted - 06/12/2003 :  13:46:57  Show Profile
Where do you get those? Catalina Direct?
Response Posted - 06/12/2003 :  14:42:06  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>Where do you get those? Catalina Direct?<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Yes, Catalina Direct has them($7.95ea plus shipping). You can also get them from SailNet($5.95ea and no shipping).
http://www.sailnet.com/store/item.cfm?pid=20087
North Star SR/FK
Headhunter
Response Posted - 06/12/2003 :  14:54:43  Show Profile
Thanks, Don...You da man.
Buzz Maring
Response Posted - 06/12/2003 :  15:04:52  Show Profile
<font color=blue>Yes, Catalina Direct has them($7.95ea plus shipping). You can also get them from SailNet($5.95ea and no shipping). - Don</font id=blue>
Thanks, Don ... I need them, too. I already ordered them from SailNet. Unfortunately, they are on backorder ... 'no big deal though ... I'll get by with the Mickey Mouse crap that's in the track for now.
Buzz Maring
~~Freya~~
C-25 SK/SR #68
luckystar
Response Posted - 06/12/2003 :  20:04:12  Show Profile  Visit luckystar's Homepage
Okay, so what's the approx. height of a boom on a standard rig need to be? I've often wanted to put a black stripe like I''ve seen on the racers boats so that I can be a little more consistant and make sure that my downhaul on the boom is set right. If anyone has the measurement, i'd sure appreciate it.
I got tired of my boom sliding all the way down and after I bought Joe Martinek's slide gate covers, I used the same same sail track stop under the boom about three inches lower than my down haul length. That with the topping lift set so that when hoisted it's slack and when not it's still up (not head bonking when I've forgotten to set it before releasing the halyard! Doh!)
But I'd still like to know where it needs to be. And speaking of that, how close should the main sail luff be to the masthead. I've never really had troubles by pulling it up all the way, setting the downhaul to chosen tension, but I'm just curious. Now that I'm getting addicted to Racing, I really want to tweak the hell out of Lucky Star!!
Patrick Burnett, Little Rock, AR
S/V Lucky Star #2707 1982 SK/SR<br>
<img src="http://www.proxycreative.com/clients/luckystar/luckystar_0602_sm.jpg" border=0><br>
http://www.proxycreative.com/luckystar.html
SEA DOG
Response Posted - 06/12/2003 :  20:31:17  Show Profile  Visit SEA DOG's Homepage
A SS self tapping panhead screw in the mast track.
Seadog FK/TR 4232
