I have read in several books that if the sails are trimmed properly, the boat will steer itself. Yesterday the tiller felt a little strange...almost like the rudder was no longer attached. I realized what was happening and let go of it, and the boat kept sailing straight ahead. It was pretty cool. My crew broke out the video camera and taped a few seconds of it until the wind shifted. I think I've had such difficulty in the past due to the strong current (2-4kts) in our old sailing grounds.
It's always great to play and learn. I can remember some of those events myself. Learning finaly how to trim the sails just right and find the (((GROOVE))). The trick is to remember how you did it.
Sorry, folks, but a neutral helm is not ideal from several points of view.
First, a slight amount of weather helm induces lift from the keel, which pushes the mast to windward giving you more power.
Second, a small amout of weather helm is simply safer. Whatever goes wrong (including you falling overboard), if you let go of the tiller, the boat finds its way up into the wind.
So, if you want to go slower upwind, set your rig for a neutral or lee helm. If you want to go faster, set the rig for 4-5 degrees of weather helm in 10-12 knots wind, so that if you let go of the tiller upwind, the boat luffs up in a few seconds.
Generally, if you have the rig set this way and trim your sails for a neutral helm, you'll be sailing slower. And while I'm not a racer, I got this from a professional racer and rigger.
Aw come on Mr. Bristle don't spoil the fun! <img src=icon_smile_wink.gif border=0 align=middle>
It may not be the fastest or safest way to trim the sails but haven't you read accounts of sailors losing a rudder and sailing by trim alone. I always wanted to try is some day too. That and heaving to such that I can stay in one place or nearly so are two things I want to play around and have in my skill set- just in case.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I think weather helm has to do with rig tuning more than sail trim. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> I think it has to do with everything that can affect the center of effort--the rake of the mast, the relative sizes of the main and headsail, the draft of the sails, and the relative trim of the two sails. At one extreme, most boats under jib alone will have lee helm. If you can achieve neutral helm, then you can probably make some adjustments to the relative trim of the sails to turn up or down (weather or lee helm).
Heel also affects the helm as the underwater hull form becomes asymetric--with the lee side forming a "wedge" that pushes the bow to windward. This becomes more noticable as the rudder begins to lose its efficiency due to (1) less of the blade being in the water, and (2) the blade not being vertical--therefore not creating strictly horizontal turning forces. As the boat heels and the hemsman corrects for weather helm, the rudder starts driving the bow down, as well as creating its own drag. That's another reason that sailing upright contributes to speed.
OK, Todd, are we having any fun yet? <img src=icon_smile_cool.gif border=0 align=middle>
I was thinking of what was set, as opposed to what was variable. All the sail trim, you can undo in a moment, but if the standing rig is set with neutral or lee helm, you can't quickly adjust that.
For me a little weatherhelm gives a more accurate feel of the forces at play, and any changes. A puff, eyes closed, can be felt in the tiller if the slight force increases a little more....neutral helm is like a car without toe-in it wonders slightly instead of tracking.....but that's also somewhat a matter of personal preference.
The statement I cannot resist (sorry, I navigate for a living) biting into is:
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I think I've had such difficulty in the past due to the strong current (2-4kts) in our old sailing grounds. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Current is the water moving over the ground. The boat does not know this. It affects where you end up, and how fast. It does not affect boat handling, ie. trim/boat speed/weatherhelm what have you in any way shape or form.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Current is the water moving over the ground. The boat does not know this. It affects where you end up, and how fast. It does not affect boat handling, ie. trim/boat speed/weatherhelm what have you in any way shape or form. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Well, Oscar, as a navigator, (commericial aircraft, right?) you know that in a current, if you "point" the boat at a landmark and try to sail to it, you find yourself changing your course relative to the wind as you go along--possibly to the point that you end up pointing to high and are unable to make your landmark. That could be the kind of "difficulty" Tray was having. And that's where a GPS is a wonderful thing!
Dave, I understand what you saying, and I don't disagree. I just wanted to make sure Tray saw it that way too. IOW, sail the boat first, in relation to the wind, then figure out if it can get you where you want to go, change the plan if needed......You know what's even nicer than a GPS? Three of 'em....<img src=icon_smile.gif border=0 align=middle> ( on the plane not on Lady Kay)
