My 250 has developed a yellowish stain on the topsides just forward of one of the starboard lifeline stanchions and to the right of the mast (just forward of the starboard "portholes" (windows). This is a new boat; less than 6 months old. I have tried fi
Can't imagine what would do that but if you suspect it's a rust type stain, try "On&Off" Hull and Bottom cleaner. An acid based cleaner that removes that brown water line stain very easily even in my old hull. Just wipe on and hose off. Before I found
Try a little CLR (Calsium,Lime and Rust) remover or even bleach. Just be sure to follow it up with a good wash and fiberglass finish restorer like 3M's product. Good Luck and Happy Holidays
With such a new boat, you may want to contact Catalina. Could be a latent factory issue. Even if the discoloration is new, the source could be within the gelcoat during the finishing process?
Thanks for all your help, guys. I did contact Catalina and they advised using a mixture of Bon Ami and alcohol. Alternatively, they suggested using Armor All. I'm anxious to see how this works.
I have a two year old 250 WK. It also has developed a rectangular patch of yellowing just foward of the mast. I have not found anything that would restore the original white color. I just assumed that it was a discoloration of the gelcoat caus
