 Barrient winches
Dan86
Initially Posted - 06/18/2003 :  22:35:25  Show Profile
I have noticed barrient winches on several pictures of the boats in this forum. I have two on the cabin top that I can't figure out how to keep them from pulling up. I have gotten the schematic and do not seem to be missing any locking rings, or anything as simple as that. Any of you with similar experiences? thanks dan86
Response Posted - 06/21/2003 :  10:55:27  Show Profile
I take it the winch spool is pulling up off the body ???
'78 Catalina 25
Dan86
Response Posted - 06/21/2003 :  22:45:22  Show Profile
The entire body comes up when a load is placed on it. (actually occurs on both cabin top winches. I have come close to loosing the body before I noted that it was lifting. Dan
Response Posted - 06/22/2003 :  09:41:56  Show Profile
Not sure I'm fully grasping your problem yet.
The winches are through-bolted to the cabin top.
Are the bolts loose or the holes wallowed out ?
I googled on Barient Winches... here's a few links that might be useful.
This one, Ericson Yachts has downloadable Barient winch manuals !
http://www.ericsonyachts.com/specs_and_docs/doc_index.htm
Here's some others...
http://www.marinersguide.com/dockswap/california/messages/788.html
http://www.j30.org/html/technical/articles/j30-winches.html
http://www.arco-winches.com/
'78 Catalina 25
Response Posted - 06/22/2003 :  11:37:49  Show Profile
Dan - are you sure that you have circlips on the top of the winches? Missing these is the only way I can imagine that the body can rise up.
Derek
TRFK#2262"This Side Up"
Dan86
Response Posted - 06/22/2003 :  22:01:04  Show Profile
You'll have to pardon my lack of winch nomenclature, but the actual interior portion of the winch that is bolted to the cabin top stays on deck, the outside cylindar raises up. I have looked extensively and do not think I am missing the retaining ring at the top, but could be wrong. Dan
Response Posted - 06/23/2003 :  10:19:29  Show Profile
That's the "Spool" or "Drum" that is lifting then... the winch body is what's bolted to the deck. The manuals posted on the Ericson site may be what you need.
What model is your winch ?
'78 Catalina 25
