 more about my 9.9. cavitates a lot???
77Gypsy
Initially Posted - 06/21/2003 :  20:28:06  Show Profile
i have the extended shaft of 25". it seemed the prop was only submurged about 5-6 inches. the mount was on the farthest down position possible. is that ok? when i had one person standing on the bow, the motor was making a horible noise.
questions:
1. could this be affecting the speed?
2. should i replace the mount?
3. should i lower the bracket on the transom a few inches?
Steve
78 C25 SR/FK - Gypsy
<img src="http://www.websdf.com/gypsy_sign.jpg" border=0>
Response Posted - 06/21/2003 :  21:22:24  Show Profile
"the motor was making a horible noise"
Yowser... don't run your motor with the lower unit popped out of the water. You'll ruin your water pump in very short order !
... regarding cavitation/motor position...
Maybe... if it's cavitating all the time. When cavitating, the motor will rev up because it's not doing much work pumping air into the water. As a test, get some extra weight in the stern and see what happens when you know the prop is well buried. Where's your anti-cavitation plate in relation to the water ? It should be buried 4" to 6" or so.
Dunno, what mount do you have? Some mounts have more 'throw' than others and depending on your current mount bolt hole situation, replacing the mount may/may not be easier than item #3 below
Not a bad idea as long as you can get the motor clear of the water and it's not so deep that the powerhead gets swamped.
Regarding your speed problems in general ?
How do you know you're making 2kts ? GPS or Knotmeter?
Over ground or water speed?
What prop do you have on the Honda ? A speed prop or a power prop?
For a sailboat, you want a power prop.. low pitch, big blades. Even with the speed prop you should still easily make your hull speed.
Why is the prop covered with Barnacles? Are you leaving the motor down in the water? (most folks raise them when not in use).
What kind of shape is your bottom in ? Do you have fresh anti-fouling paint on? If not, you may have so much growth (friction) that you aren't going to go anywhere fast until you clean it.
'78 Catalina 25
Bill Holcomb
Response Posted - 06/22/2003 :  09:43:01  Show Profile
Hi Steve,
We need more info. What engine do you have and what outboard bracket?
But, running the engine with the lower unit & prop out of the water is NOT a good thing.
thacket3
Response Posted - 06/23/2003 :  15:10:23  Show Profile
I have a "kind of" related question to this. When my motor braket, holding a 9.9 HP engine is inthe "all the way down" setting, I noticed that the thrust of the engine pushes the bracket inward. (the springs that lift the engine) this does not happen when the mount is inthe middle position. But I like having the motor as deep as possible to prevent cavitation. Is this "spring" ok? or is it time to replace the mount itself? I would hate to be motoring and loose the motor.
Anyone have any thoughts?
Response Posted - 06/23/2003 :  15:40:15  Show Profile
. . . when my motor braket, holding a 9.9 HP engine is inthe "all the way down" setting, I noticed that the thrust of the engine pushes the bracket inward . . .
Maybe this falls into the high thrust category?
What motor and what bracket do you have?
77Gypsy
Response Posted - 07/03/2003 :  22:46:50  Show Profile
not sure of the motor bracket. it came with the boat. it doesn't look stock though.
i have the fancy honda 9.9 4 stroke with a 25" shaft.
the cavitation plate sits about 1 inch under the waterline. when i have a bit of chop the motor comes out of the water.
Steve
<img src="http://www.websdf.com/logo.jpg" border=0>
deastburn
Response Posted - 07/04/2003 :  00:12:28  Show Profile
I have the Honda 9.9 with a 28" shaft, which is what is recommended for sailboats. All O/B brackets are not created equal, and the difference between a nine inch travel and a fifteen inch travel, coupled with the shorter shaft, could easily have your motor popping out of the water when someone spits. I should add, if only for consolation, that my 28" 9.9 Honda on an OMC bracket cavitates in any kind of a chop, particularly on the way into and out of harbor channels, where the tide often runs against the wind. Outboard sailboats work best on small lakes. Given that, occasional cavitation, as in a severe chop or swell, will not destroy your motor. Prolonged cavitation will. So, give us more information...
77Gypsy
Response Posted - 07/07/2003 :  04:31:52  Show Profile
i guess it only really happens when i hit some wake. other than that, i'm pretty much ok. i may lower or replace the bracket next year, possibly to get the prop about another 4 inches under water. it's on my many "to do's" list.
Steve
