 Pintles & Gudgeons
teamwike
Initially Posted - 12/17/2001 :  20:50:04  Show Profile
Hello looking for info on how to replace pintles and gudgeons on my 1982 Cat 25. I have ordered the beefed up set, but not sure how to get behind the transom to the nuts and backing plate. ( if there are any?) I saw the photo in "tech tips" where someo
Bill Holcomb
Response Posted - 12/18/2001 :  10:51:49  Show Profile
Hi Max,
The inspection port is by far the easiest solution for the uppper gudgeon. The lower one can usually be accessed from inside the boat....either from the portside cockpit compartment or from the quarterberth inside the main cabin.
Bill Holco
andy p
Response Posted - 12/18/2001 :  15:32:28  Show Profile
I had the same problem and found it very painful cutting into that nice clean glass. I did it but now I'm thinking even that was a mistake. I'd say if you can leave the top gudgeon alone, do it. I suspect it's the bottom bits that are doing all the hea
John Mason
Response Posted - 12/19/2001 :  17:12:53  Show Profile
Hi,
I did that last winter on my '82 and found that there are no nuts, just a piece of brass 1" x 5" behind each gudgeon glassed into the transom from the inside that has threaded holes. I thought I'd broken the bolts removing the old gudgeons, so I grou
Douglas
Response Posted - 12/19/2001 :  17:28:49  Show Profile  Visit Douglas's Homepage
If you do end up cutting a hole you can make it look nice by using a deck plate access port to refill the hole. 10 to 12 dollars at West Marine
jwilliams
Response Posted - 12/19/2001 :  19:04:34  Show Profile
Hey Teamwike, (is that a real name? pardon my ignorance.)
With all respect to Mike P. I disagree with his suggestion that it is ok just to replace the lower pintle/gudgeon.
On Hey Jude, the upper gudgeon screws worked themselves out of the brass pl
teamwike
Response Posted - 12/19/2001 :  19:35:03  Show Profile
Thanks for all the information. JWilliams--"Teamwike" is an old team name that my brothers and I used when we used to race together. My name is Max Wike. Boat's name is " Legolas".
Thanks again, saved me a lot of headaches.
jwilliams
Response Posted - 12/21/2001 :  09:09:54  Show Profile
Hey Max,
Teamwike. Got it.
Legolas. It seems Tolkien fans are popping out of the woods all over. (Pun intended)
Jim
Hey Jude C25fk 2958
