Has anyone had sewage run up the vent hose while flushing the toilet? I replaced the hose, checked for kinks and a clogged vent. It's almost as if the vent diameter is too small. When I disconnect the vent hose at the tank, it works fine. Only when I attach the 5 foot vent hose does liquid run up the hose.
If the vent hose is attached to the top of the holding tank, how is liquid getting up to it?
When my holding tank gets a little too full <img src=icon_smile_dead.gif border=0 align=middle> and I'm doing some serious heeling, I have seen a blue stream come from the vent outlet. That lets me know that it's time for a pumpout.
Your question is my question. The tank is only about a quarter full. Somehow I think the air is not excaping fast enough, and the water is chasing it out???? I'm going to try a larger diameter hose, or and or see if the elbow fitting at the tank is partially obstructed.
When we first got Swept Away, we found the vent fitting itself totally blocked. We removed the hose, and used a small screwdriver, both from below, and above to clear the debris. There was a small metal screen in the vent that we removed. Now, we flush the line out occasionally by holding a water hose to the outside vent for a few seconds. (Holding tank cap open.) No problems since.
-don
Don & Freda Jones "Swept Away" '83 C25 SR/FK Charlotte, Southport, NC
We have had it come out of the vent when we were heeling and the tank was full.......
I would make sure that the vent line is on the top of the tank and that your tank is empty.
If you are saying when you disconnect the vent hose it works fine. I would take the vent cover and clean it. Maybe when your pumping you are filling the tank with pressure and the "stuff" is forced up. Can't see how.
While we're on the subject and for what it's worth. When I designed my holding tank setup, I decided on two 1" vent lines out the top centerline of the tank. They vent to atmosphere via nylon thru-hulls just below the whale-eye nav. lights. The aerobic bacteria (good bugs) get all the oxygen they can use. I don't expect to ever have a pressurized tank problem from a clogged vent.
