 Mainsheet Attachment
JoergK
Initially Posted - 07/17/2003 :  10:48:19  Show Profile
The block of the mainsheet assembly was attached to the end of the boom with a metal strip (they call it a "tang"?). This strip broke. I would guess that over time the load - always coming from different angles and sometimes even from the side when the boom is all the way out - would cause metal fatigue and the tang will fail. As a temporary solution I attached a toggle to the eye on top of the boom (where the topping lift usually attaches). Does anyone know of a better solution? The toogle pin will eventually fail exactly for the same reason (shear-load).
Joerg
86C25 SR-SK Second Wind
Brooke Willson
Response Posted - 07/17/2003 :  12:05:19  Show Profile
Joerg, when the bolt holding my tang to the boom end came loose and disappeared inside the boom, I put a stainless steel bail on the boom, and attached the upper block to that with a shackle. The bail allows the block to slide with the position of the boom. I think it's a vast improvement over the tang.
Brooke
JoergK
Response Posted - 07/17/2003 :  14:47:46  Show Profile
Brooke, thank you for the advise. However, excuse my ignorance, what exactly is a "bail"?
Joerg
Response Posted - 07/17/2003 :  15:41:25  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>What exactly is a "bail"?<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
It is a piece of spar hardware, mostly used to secure the ends of a vang to the boom and mast.
<img src="http://www.sailnet.com/store/prodimage/160x160/sch90-09.gif" border=0>
North Star SR/FK
JoergK
Response Posted - 07/17/2003 :  16:36:17  Show Profile
Don, Brooke, this is great. I'll do that. No use having the boom take off just when it blows hardest.
Joerg
Response Posted - 07/17/2003 :  17:33:59  Show Profile
Joerg - the tang on "TSU" broke at the boom in the last race on the first day of a 2-day Regatta. My foredeck guy took it home, ground the broken end smooth and drilled another hole. We've used it ever since!
Derek
TRFK#2262"This Side Up"
Response Posted - 07/17/2003 :  18:50:22  Show Profile
New tangs are available through a Catalina dealer. I just bought a spare, just in case....
