 M'sail Trim
frich
Initially Posted - 07/21/2003 :  09:05:08  Show Profile  Visit frich's Homepage
Along the foot of my main sail, i have a pronounced "bag" (sail not stretched properly. My outhaul is stretched to the max, the sail is atop the mast, and the cunningham is tightened.
Is it time for a new sail? Am I getting optimal performance running like this? I have also noticed some sails which are not secured along the boom track. Can I remove mine from this track? If so must I also remove the protecting layer running along the foot of the sail?
Frank R
84 C25 SK
Dave B
Mali
Response Posted - 07/21/2003 :  09:22:42  Show Profile
Frank: Your sail may be cut with a "shelf" at the foot--intended to maintain the airfoil shape close to the boom, instead of making it board-flat down there. You get the same effect from a loose-footed main (attached only at the tack and the clew). Have a sailmaker look at it--it may be a tired sail, or it may be the design. If you go loose-footed, you may get approximately the same shape, although it'll be adjustable for wind speeds (looser/fuller in light wind).
Response Posted - 07/21/2003 :  09:55:59  Show Profile
Some folks pay lots of money for custom racing sails with that 'shelf'. ;>)
If it's a 'stock' sail and has a big 'shelf' it's probably blown out. If not a stocker, that bag may be there 'by design'.
'78 Catalina 25
Brooke Willson
Response Posted - 07/21/2003 :  09:59:38  Show Profile
Frank, my 1985 TR mainsail had a pronounced shelf at the foot when I acquired it. It was pretty blown out from use. To save money, I took it to a local sailmaker who recut the foot of the sail, and extended the life of the sail by several years. I think it cost about $ 150, which is a whole lot less than a new sail. I agree with Dave: take it to a sailmaker for evaluation and suggestions.
Brooke
Douglas
Response Posted - 07/21/2003 :  11:58:51  Show Profile  Visit Douglas's Homepage
Its hard for a sail maker to tell you whats wrong by just taking the sail in. Take pictures of it when its up and on the boat. It will help the loft alot.
Doug&Ruth
Triska (Alberg 29)
Tacoma Wa.
frich
Response Posted - 07/21/2003 :  12:07:58  Show Profile  Visit frich's Homepage
Thanks for the info
Frank R
