 step removal
pierrem
Initially Posted - 10/20/2003 :  22:24:35  Show Profile
I plan on refinishing the teak this winter. I have a swing keel/tr. Any precautions in removing steps with the swing keel winch attached to the steps?
Pierre
Response Posted - 10/20/2003 :  23:21:01  Show Profile
I guess it goes without saying that you should make sure the keel is lowered onto a support!
When I took mine out, I unspooled some slack from the winch, unbolted
the stairs, and removed the winch after taking the stairs out. (It is easier to get at the bolts and remove the winch with the standpipe out of the way). Only other precaution is not banging things up.
Reverse the process for re-assembly.
While you're in there, be sure to inspect the turning ball and replace if necessary.. Replace the special (stainless reinforced) rubber hose, and use 2 new stainless hose clamps. I also put some non-adhesive marine sealant around the inside of the hose where it fits over the hull fitting.
Do all this work before putting the winch/stairs back in.
WOTAM - '77 Catalina 25 SK/SR Sail Number 158
CatalinaGuy
Response Posted - 10/21/2003 :  10:58:38  Show Profile
The stairs are a structural support, and are under some compression loads. I had to use a floor jack to lift the cockpit floor a bit to get the stairs back in.
Doug Hibberd, 'Shiraz'
C25 SK/SR 1983
Austin, TX
Sea Trac
Vanuatu
Response Posted - 10/21/2003 :  11:46:16  Show Profile
I also intend to refinish my stairs this winter. My desire is to use varnish. However, the crappy old rubber skid plates fell off last year and the unfinished wood has been very slippery, and I know that varnish will make the situation even worse. So, I'd like to make the steps non-skid. Any suggestions on what material to mix with the varnish to acheive this, while not sacrificing the finish or ending up with a bloody sole (triple entendre intended)?
J.B. Manley
Antares '85 FK/SR #4849
Grand Lake O' the Cherokees
36°29'58" -94°59'59"
Response Posted - 10/21/2003 :  13:04:57  Show Profile  Visit Frank Hopper's Homepage
J.B. Manley
Defender had a lot of self-stick non-skid products in their catalog, swimming pool people have granules to add to deck paint. How about those peel and stick duckys for the bottom of a bath tub?
<img src="http://members.cox.net/fhopper/Catalina25/sigbow.jpg" border=0>Frank and Martha in Wichita KS. Lake Cheney
RichardG
Response Posted - 10/21/2003 :  16:07:48  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>make the steps non-skid <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
The previous owner didn't like the look of the old rubber plates and removed them. Then he simply refinished the stairs with varnish and afterwards carefully put down dark gray, stick-on non-skid strips purchased from Home Depot. He trimmed the corners very well. It looked great for about 4 years, but a couple years ago they started coming up a little, especially on the top step. Re-doing them is on my to-do list, although I don't expect it to be difficult or very expensive.
<img src="http://im1.shutterfly.com/procserv/47b3ce00b3127cce8029b2e0caed0000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3ce26b3127cce8ff91ad9f9d90000001010" border=0>
Randall
Response Posted - 10/22/2003 :  21:22:51  Show Profile
I'm stunned to hear that the ladder is a structural member in the boat! I was considering modifying the ladder to make enough legroom to create a "captain's chair" with the back against the starboard side, and feet extending into the galley area. Gonna have to rethink that.
CatalinaGuy
Response Posted - 10/23/2003 :  17:41:27  Show Profile
I removed the ugly rubber pads on mine and refinished with Cetol (because it handles abuse better than varnish). Then I cut treadmaster non-skid (the fine grade) pads and epoxyed them in place. Works great, lasts forever, and looks awesome.
nate
Response Posted - 10/24/2003 :  12:41:05  Show Profile
Richard G,
What is the small cleat on the port side of the stairs for? Just wondering..........
Nate Adams
C25 # 5695 WK/SR/Trad
"Heeling Properties"
Lake Mead, NV
RichardG
Response Posted - 10/27/2003 :  13:49:56  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">What is the small cleat on the port side of the stairs for? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Sorry for the delayed response. Just got back from visiting the very scenic Morro Bay area (camp'n, fish'n, Hearst-castle'n, etc.) and found So. Cal. is burning again...ash everywhere! I assume on my boat, too -- need to wash that off tonight.
Anyway, the rope leads through a couple padeyes to the underside of the big cockpit locker door...cleating the rope locks the door. It works well. A previous owner (San Diego area) did it after someone broke in and stole a bunch of stuff. You can see the repair where the old exterior lock was mounted -- the fiberglass is pretty thin there (both the lid and the side of the cockpit).
