 Standing Rigging Question
cch
Initially Posted - 10/21/2003 :  08:10:00  Show Profile
After great comments and suggestions from the forum I am replacing the standing rigging on Moonglade. The PO had installed spreader boots and I had never seen what was under them until this weekend. I am not sure if the small wire wrapped around my spreaders is the best way for this to be put together.
How is the connection between upper stays and spreaders usually made?
I feel I will put spreader boots on again so it is more about function that how it looks.
<img src="http://im1.shutterfly.com/procserv/47b3ce01b3127cce802099f433be0000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3ce01b3127cce80209b8f33c40000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3ce01b3127cce80209c65f2850000001610" border=0>
Chris Hunsicker
Panama City FL
Moonglade
80 C25 #2126 sr/sk
<img src="http://im1.shutterfly.com/procserv/47b3d636b3127cce8c9d4c83e7890000002010" border=0>
Bill Holcomb
Response Posted - 10/21/2003 :  09:32:32  Show Profile
Hi Chris,
It looks like your PO did the job about right. The little wire is there to hold the upper shroud to the spreader tip. Your photos appear to be pretty much how Catalina described the process.
Response Posted - 10/21/2003 :  09:46:22  Show Profile
Chris,
I'm not entirely sure, but it looks like you may have the old aluminum spreader bracket casting. If you do, you may want to consider installing the newer stainless steel bracket while you are upgrading the standing rigging.
<img src="http://im1.shutterfly.com/procserv/47b3da02b3127cce9693e5fceeb30000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3da02b3127cce9693f3b3eef70000001610" border=0>
North Star SR/FK
Bill Holcomb
Response Posted - 10/22/2003 :  08:15:46  Show Profile
Chris, I agree with Don. The photo that shows your spreader base does look like the old aluminum bracket. That bracket was originally designed with only up to about a 125% jib in mind, and protected waters sailing. Of course, within a couple years of the boat being introduced, skippers were racing with 155% genoa jibs, spinnakers, and in strong winds. Mast failures were inevitable.
I don't remember the exact year, but it seems like the early eighties, Catalina introduced the SS spreader base as an "in-line" production change and recommended skippers of previously produced boats retro-fit to the new stainless steel system. That recommendation is a good one. The ~$50 expense for the new spreader base is pretty inexpensive insurance compared to the expense associated with a catastrophic mast failure.
Also, the wooden spreader tips on older boats were replaced with delrin (sp) plastic spreader tips at around the same time.
cch
Response Posted - 10/22/2003 :  12:36:13  Show Profile
Bill,
I have the same concern as you and Don, and my brackets do appear to be the old design. My question is that the old aluminum brackets are cast and on my brackets the socket is welded to the plate which leads me to believe they are stainless. What do you think?
<img src="http://im1.shutterfly.com/procserv/47b3ce03b3127cce80d33c2022200000001610" border=0>
Chris Hunsicker
Panama City FL
Moonglade
80 C25 #2126 sr/now wk
Response Posted - 10/22/2003 :  13:43:17  Show Profile  Visit Champipple's Homepage
Chris -
Those are the newer brackets
<img src="http://www.flags.com/images/layout/category_images/t_3964.jpg" border=0>
Response Posted - 10/22/2003 :  14:43:21  Show Profile  Visit Frank Hopper's Homepage
Chris -
D. Wolff -
Duane said it
I believe it
That settles it
<img src=icon_smile_big.gif border=0 align=middle>
<img src="http://members.cox.net/fhopper/Catalina25/sigbow.jpg" border=0>Frank and Martha in Wichita KS. Lake Cheney
cch
Response Posted - 10/22/2003 :  19:15:34  Show Profile
Works for me!
Chris Hunsicker
Panama City FL
Moonglade
ronrryan
Response Posted - 10/22/2003 :  21:56:46  Show Profile
Chris, the function of the wire, it should be told, is ONLY to hold the shroud wire into the slot in the spreader tip, NOT to locate it or prevent it from moving. The wire will shrink or elongate according to its needs and load,the wire should let it do so. The socket of the spreader is supposed to set the proper angle for the spreader arm or tube, which is supposed to bisect the angle made in the wire as it passes over, on its way to the masthead. Hopefully this minor clarification does not further obfuscate matters, god bless, ron srsk Orion
cch
Response Posted - 10/23/2003 :  01:53:47  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ronrryan</i>
<br />Chris, the function of the wire, it should be told, is ONLY to hold the shroud wire into the slot in the spreader tip, NOT to locate it or prevent it from moving. The wire will shrink or elongate according to its needs and load,the wire should let it do so. god bless, ron srsk Orion
Ron,
I noticed the shroud was able to slide through the wire easily so I am going to try to put it back together exactly as it was.
