I read that article too. I wonder if it was the pressurized, Princess curtain-burner (which would be my guess, since fuel was coming out of the filler cap), or was it another type (since the Princess usually comes with a stainless steel catch basin under the stove, at least on our boats)?
The Origo 3000 is a non-pressurized, absorption-burner stove, much safer than the pressurized "curtain burner" stove that comes with the Catalina 25. The only problem with the Origo is that by nature of the fuel tank design, there is a constant loss of fuel through evaporation, especially in the hot summer months when most people are using their boat. I would guess that of every gallon of alcohol you put into an Origo 3000, you lose at least 10% per week by evaporation. It wouldn't matter so much if alcohol were only $1.50/gallon like gasoline, but at $8.50/gallon at Home Depot, or $10.00/gallon at West Marine, it hurts to think of how much stove fuel you lose out of an Origo. Last year, at the beginning of the season (April 1st), I filled my Origo to the brim and put on a new seal gasket. 6 weekends later, which was the next time I used the stove, the tank was practically empty and I had to put in nearly a full quart to top off the left side tank (I usually only use one tank to limit the loss of fuel). I have pretty much abandoned both of the alcohol stoves I have and usually use a Coleman 2-burner propane camp stove on the boat. The 16 ounce propane bottles are cheap, last several weekends for the minimal amount of boat cooking I do, and they are also used to fuel the boat barbeque when I bring steaks or chicken for dinner. I store the propane in the portside cockpit tray, so if it leaks, it just runs out the cockpit drains or blows away, and doesn't become an explosion hazard inside the boat.
Larry Charlot Catalina 25WK/TR Mk. IV #5857 "Quiet Time" Folsom Lake, CA
Over many (more than fifty) years on the water, probably thirty-five cruising, I have encountered three fires on board, and observed two more from afar. All were shockers to me, who grew up in an era when a coal or wood ("solid fuel") stove was a customary fixture in New England waters. These fires were caused by alcohol stoves, with their nearly invisible flame, "flaring" up and igniting --yes, the curtains--or something nearby, and setting off the whole outfit unless immediate remediation ensued. I was involved in putting out two of these fires at docks where we were visiting. I think Pat and I got used to being skilled and careful in early boats when we had kerosene "Primus" stoves, which had to be primed with alcohol until the burners were ready to vaporize the fuel, and then worked perfectly, indeed, were so hat you needed spacers under the pots to get a simmer. Nowadays we cruise much less, and use the butane canisters that are silly for extended cruisers, but fine for dabblers like us. I had a sailboat for many years wherein I took out the alcohol stove and put in a drop-in Origo, which was quite satisfactory for weekending, might have been less so for real cruising. Alcohol pressure stoves are fine for folks who WILL follow guidelines and learn to have the patience and skill to use them properly. For all others they are a fire waiting to happen. When I taught seamanship for the Power Squadron, I would say "The Coast Guard requires alcohol stoves because they are so easy to put out with water. On the other hand, their statistics indicate that eighty percont of boat fires are caused by alcohol stoves. Go Figure!" God bless all here, ron srsk Orion SW FL (on the hard, at the moment)
