 Standing Rigging
frich
Initially Posted - 10/29/2003 :  16:10:13  Show Profile  Visit frich's Homepage
Probably been talked about before, but with my mast down I want to inspect my rigging (20yrs old this year) I know the obvious meat hooks and rust, but is there any area above all others that has a history of failure.
Thanks to all who reply
Frank R
84 C25 Sk
Response Posted - 10/29/2003 :  17:52:17  Show Profile
If you have the aluminum spreader sockets you should carefully inspect them for corrosion damage, cracks etc. Apparently some of these have failed.
There is a replacement kit available from Catalia-Direct with all-stainless steel construction. (I upgraded mine, easy job.)
Ditto for inspecting the aluminum masthead fitting and related hardware... somebody on this board had that component fail awhile back... as I recall, they lost their mast when it went.
Be sure to look for cracks and corrosion damage in all the shroud end fittings.
