As I was sailing my c25 to her winter resting place, I noticed that my knot meter and my depth finder was not working. I checked all the other electricl appliances and everything works. I even checked the batteries and all the fuses are good in the circuit braker. Any ideas
Having a VOM (Volt-Ohm-Meter) is pretty handy for troubleshooting problems like this. An inexpensive variety from Radio Shack will tell you if you have voltage to the knotmeter connections.
If you have 12V at the terminals, there is a possibility that the unit itself has failed. Otherwise you'll need to trace the power supply wires back to their source and see where you 'lose power' in the circuit.
Corroded or otherwise degraded connections are often the cause of problems like this.
Make sure that you check the battery terminals as well as the connections at the switch panel for corrosion. It doesn't take much to restrict those little electrons. Of course, if the 12VDC circuits to your knot meter and depth sounder have wire splices, check these as well.
When you say "not working", do you mean giving no readout at all (ie. "switched off") or simply reading out "0.00"? If the latter, I would suspect algae or weed buildup if the boat has been in the water for long, and not an electrical problem. (No matter what coating I use, my paddle-wheel knotmeter has never gone an entire season in the water without the need for underwater cleaning.) If you have simply blank screens, then they must be getting no juice, since even a bad depthsounder will give some kind of a readout (usually "-.--"). Besides, it is highly unlikely that both went bad at the same time. In addition to checking the panel fuses, I'd suggest you also check the inline fuses, since it is likely that each of these instruments has both. Simply follow the wires back to their connection with the power source (which should be the main or auxiliary fuse panel), and you'll find an inline "Buss-type" fuse. Good Luck!
Ken, I don't know your exact problem i.e. no power or not working right, but my depth sounder sort of works as a voltmeter for me. If the voltage on my batteries gets too low, the depth sounder stops working. Then I know its time to charge the batteries. Ditto on the suggestion about checking with a voltmeter.
Loren Souers, skipper Nimue, the Lady of the Lake (on the hard til May )
