 Maiden Voyage of "Quiet Time II"
lcharlot
Antigua and Barbuda
Initially Posted - 11/10/2003 :  01:23:10  Show Profile
I finally got my new boat fully rigged up and ready to take out sailing this weekend, and had a wondertime time despite the stormy weather. One benefit of bad weather is it does bring wind. I had steady breeze of 10-14mph from the southeast both Saturday and Sunday, and I can report that she sails beautifully! The trip odometer on the GPS shows I put 35 miles under the keel this weekend. Here are some photos:
http://webs.lanset.com/lgcharlot/sailing/5857-2/delta.htm
Larry Charlot
Catalina 25WK/TR Mk. IV #5857 "Quiet Time"
Folsom Lake, CA
"You might get there faster in a powerboat, but in a sailboat, you're already there"
Oscar
Response Posted - 11/10/2003 :  09:19:01  Show Profile  Visit Oscar's Homepage
Sounds like all your hard work is paying off. Enjoy.
Oscar
250WB#618 Lady Kay on the Chesapeake
osmepneo
Response Posted - 11/10/2003 :  11:51:54  Show Profile
Larry, can you compare the performance between QT I and QT II?
deastburn
Response Posted - 11/10/2003 :  15:30:55  Show Profile
Great pics! There is a C25 moored in Onset Harbor, near the Cape Cod Canal, also named "Quiet Time".
Response Posted - 11/10/2003 :  17:04:40  Show Profile
Nice boat, Larry.
You need to move your jib sheet to the outboard side of your lifelines, because it looks like it is hanging up on them.
Oscar
Response Posted - 11/10/2003 :  18:11:50  Show Profile  Visit Oscar's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">You need to move your jib sheet to the outboard side of your lifelines, because it looks like it is hanging up on them.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Will he be able to sheet in tight then without hanging up the other way? I remember my C-30 having the same problem, and opting for Larry's compromise as it is less stress on the life line than the other way....Only if I had a long run off the wind would I re-route them.
Oscar
Response Posted - 11/10/2003 :  18:14:09  Show Profile  Visit Frank Hopper's Homepage
Catalina confused things with the mark iv they moved the genoa track inboard and screwed up the lead
Response Posted - 11/11/2003 :  10:20:28  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">fhopper@mac.com Posted - 11/10/2003 : 18:14:09
Catalina confused things with the mark iv they moved the genoa track inboard and screwed up the lead <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Oh?
lcharlot
Antigua and Barbuda
Response Posted - 11/11/2003 :  13:06:44  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by osmepneo</i>
<br />Larry, can you compare the performance between QT I and QT II?
The two boats seem surprisingly similar in the "seat of the pants feel" of sailing them. I would have expected the new boat to be more "tender" since the center of gravity of the ballast mass in the wing keel is something like 18" higher than in the swing keel. Another surprise was that the new boat sails upwind quite well on just the jib, whereas "QT1" could not do better than a 80ยบ close reach on her jib. Maybe "QTII" has a better headsail, or maybe the inboard genoa tracks on the Mk IV make a difference? Speed through the water seems about the same, except that the new boat feels like it accelerates much faster in wind gusts and when sheeting in on a tack change. I think the wing keel has less drag than the swinger since there is no keel trunk to disturb laminar water flow, and the wing is faired to smoother shape, especially on the leading edge. The lowered boom of the tall rig on the new boat will take some getting used to - it's definately a head-banger.
