 foredeck vent
kansasboatman
Initially Posted - 11/18/2003 :  00:41:02  Show Profile
On the 1978 catalina 25, can anyone tell me what that "vent pipe" or whatever is sticking up through the fordeck...just to the aft of the anchor hold.
I am assuming it is a vent...when I bought the boat last year, this "opening" was duct taped over and i have continued to do the same. However, I think this is where I am taking in water in a good driving rain...was thinking about going to a builder supply store and bnuying a flat "roof vent" to attach to this opening
kansas boatment
Response Posted - 11/18/2003 :  07:49:36  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by kansasboatman</i>
<br />On the 1978 catalina 25, can anyone tell me what that "vent pipe" or whatever is sticking up through the fordeck...just to the aft of the anchor hold.
kansas boatment
It is discontinued as a feature, I think that type of vent can be removed and replaced with a cap. I think it was supposed to make the boat look like it was from a Humphrey Bogart movie or something, it was a dated feature when it was new. Were it mine I would take it out and fill it in. Generically there is a type of vent known as a dorad box that has enough baffeling to keep most water from entering while still allowing ventalation. If you are going are going to keep the vent then simply search the sites, (West Marine, Defender, Sail Net, etc.) for vent options that would improve on what you have. If you decide to fill it in then there is a guy on this site named Leon Sisson that will provide you with excellent advise on the adhesives and materials you should consider. Here in Kansas we do not need that vent. Do you have the rectangular skylight that the rest of us have between the anchor locker and the hatch? If not I would try to replace the vent with something like that. Have you ever seen a deck light? They are very cool prisms that disperse light into a boat but are flat on the deck, that would be cool.
If Lake Cheney is selected for the Nationals I hope you will bring your boat and race, if nothing else at least come for the fun.
CB
Response Posted - 11/18/2003 :  08:19:26  Show Profile
I had the exact same hole duct-taped on the deck of my '81 when I bought her.
Rather than trying to fill it or cap it, I cut the hole a little larger w/ a jigsaw or zipsaw and installed a passive, mushroom style vent, a Nicro 500. They make a solar vent the same size, but I opted for the passive.
It actually made a bigger difference than I thought on keeping the cabin "aired out" and not as stuffy when I return to her at her slip.
I think the original hole was 2.5" , and it had to be slightly enlarged to 3". A little smear of 3M 4200 where it fit to the deck and I was done.
Good luck,
Chris
'81 sr/sk Deez Knots
Response Posted - 11/18/2003 :  09:21:03  Show Profile  Visit Leon Sisson's Homepage
kansas boatment,
I agree with Deez Knots that the foredeck vent is very helpful in providing ventilation when the boat is not in use. Here in hot damp Florida that's an important consideration. It may not be as important in other climates.
If you want to install a vent similar to the original equipment, check out the Nicro and similar cowl vents. The mushroom style vents mentioned by Deez Knots might be an even better choice, as they are less likely to snag lines or admit rain.
As Frank and Martha mentioned, if you don't need the ventilation, then filling the existing hole with a decklight prism would provide a very attractive light source in the V-berth. I have one which I received as a gift that I use as a paperweight. It's cast from antique looking glass, shaped like a hexagonal pyramid, about 4-1/2" across the flats, and has a 1-1/2" tall lip or flange around the base to support it in the deck. (They install with the pointy end down.) I don't know where to get another one, but something like that might be a convenient alternative way to fill the hole in your deck.
Bill Holcomb
Response Posted - 11/18/2003 :  12:07:51  Show Profile
The hole described on the foredeck is indeed for a "cowl" deck vent. It was a factory option through the '85 production run. But, dropped as an option from '86 on. I believe that Nicro was the mfg of the vent. And, Nicro still makes both a 3" and a 4" low profile cowl vent
West Marine and other chandleries sell these for around $30 or $35 complete. You might measure the hole in your deck and check with Nicro to see about simply buying a new vent as well as a deck cap for when you want to seal the opening shut.
Charlie Vick
Response Posted - 11/18/2003 :  13:36:01  Show Profile
"As Frank and Martha mentioned, if you don't need the ventilation, then filling the existing hole with a decklight prism would provide a very attractive light source in the V-berth. I have one which I received as a gift that I use as a paperweight. It's cast from antique looking glass, shaped like a hexagonal pyramid, about 4-1/2" across the flats, and has a 1-1/2" tall lip or flange around the base to support it in the deck. (They install with the pointy end down.) I don't know where to get another one, but something like that might be a convenient alternative way to fill the hole in your deck."
liliput.com probably has the one you have on your desk but I don't know if it would work well on a C25 deck.
CVick
PanaceaII '81 C25 #2439 SRSK
Fort Smith, AR
Response Posted - 11/18/2003 :  20:51:34  Show Profile
Are we talking about a special vent hole, or the skylight? Every C-25 I've seen has a rectangular skylight over the v-berth. Because the factory plastic lense is easy to break just by stepping on it, you might expect to find that somebody has duct-taped the opening. If it is a rectangle centered aft of the anchor locker, with a flange just below deck level, that's what it is. Catalina Direct sells replacement lenses for almost nothing, but you're better off making one of 1/2" Lexan or similar acrylic for more strength.
Roof vents from Home Dopey are not designed to keep out waves that might break over the bow. If you want to make a vent, I'd use a Dorade box type vent from a marine supplier, or even a solar vent that will run 24/7 to keep the dampness down. Remember, though, that any vent in that location is going to be an obstacle when you're anchoring or bending on a jib.
Edited by - Dave Bristle on 11/18/2003 20:58:04
Response Posted - 11/18/2003 :  21:13:17  Show Profile  Visit Leon Sisson's Homepage
Dave,<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Are we talking about a special vent hole, or the skylight? Every C-25 I've seen has a rectangular skylight over the v-berth. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Some C-25s have the rectangular lense, some have a simple cowl vent similar or identical to about a 3" soft Nicro w/o dorade baffle. It may depend on the model year.
deastburn
Response Posted - 11/19/2003 :  14:13:04  Show Profile
Yes, Leon is right. My '81 has such a cowl vent. I have never figured out how to remove the cowl so I could replace it with the deck plate that also came with the boat (but which has probably long since disappeared into some foreign tool kit). Still, I know I can purchase a plate at WM. Does the cowl simply pull or snap out? It is not on a screw thread, that much I have figured out.
BTW, I really like that vent. With the boat on a mooring it picks up the breeze and keeps the interior air moving. When I sail, I simply turn the opening toward the stern to keep the spray out.
Buzz Maring
Response Posted - 11/19/2003 :  15:45:37  Show Profile
<br />Dave,<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Are we talking about a special vent hole, or the skylight? Every C-25 I've seen has a rectangular skylight over the v-berth. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Some C-25s have the rectangular lense, some have a simple cowl vent similar or identical to about a 3" soft Nicro w/o dorade baffle. It may depend on the model year.
Like Bill said, this was a factory option ... my boat doesn't have either one.
Response Posted - 11/20/2003 :  07:36:35  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Buzz Maring</i>
<br />Like Bill said, this was a factory option ... my boat doesn't have either one.
Buzz... #68 was probably built before they decided to add a jib!
kansasboatman
Response Posted - 11/27/2003 :  00:12:37  Show Profile
Thanks to everyone for their reply and thoughts on the foredeck vent issue......at least I've got the whole winter to decide which of these excelent ideas I will use!
Happy Thanksgiving to everyone.
Kansasboatman
Response Posted - 11/27/2003 :  10:51:46  Show Profile
To whet your appetite, check out these beautiful decklights and vents from a supplier in the UK.
http://www.classicmarine.co.uk/asp/prodtype.asp?prodtype=42&ph=cat
http://www.classicmarine.co.uk/asp/prodtype.asp?prodtype=50&ph=cat
