 Tapping the goose neck
Initially Posted - 11/29/2003 :  17:39:38  Show Profile  Visit Frank Hopper's Homepage
Does anyone see any reason not to tap the cast aluminum boom end and using screws on the front of this block? I will use SS pop-rivets on the back. This is the Garhauer 25 double, it is too big but it will be ok.
deastburn
Response Posted - 11/29/2003 :  17:51:25  Show Profile
I am no metallurgist, but aren't castings more brittle and fatigue-prone than extrustions? You are talking one half inch difference in the positioning of the block. Why not simply screw it into the boom a bit further aft and avoid the question altogether?
Response Posted - 11/29/2003 :  18:15:07  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by deastburn</i>
<br />I am no metallurgist, but aren't castings more brittle and fatigue-prone than extrustions? You are talking one half inch difference in the positioning of the block. Why not simply screw it into the boom a bit further aft and avoid the question altogether?
I haven't pulled the casting so I do not know how far into the boom it goes. I would guess 3/4 ". I figure I will need to be 1" back from the end of the casting, that puts the lead almost 4" back from the mast. I am concerned about getting as perpindicular to the mast base as possible so the outhaul isn't adjusted as the boom swings around. Maybe I am not visualizing it very well and it is no big deal.
Response Posted - 11/29/2003 :  19:40:11  Show Profile
I've drilled and tapped a number of boom and mast cast pieces with no issues.
Edited by - OJ on 11/29/2003 19:44:58
Response Posted - 11/29/2003 :  20:50:20  Show Profile  Visit Frank Hopper's Homepage
<br />I've drilled and tapped a number of boom and mast cast pieces with no issues.
Thanks.
eric.werkowitz
Response Posted - 11/29/2003 :  23:35:57  Show Profile
Frank,
"I am concerned about getting as perpindicular to the mast base as possible so the outhaul isn't adjusted as the boom swings around. Maybe I am not visualizing it very well and it is no big deal."
I think it's no big deal. While the line may experience some differing in tension as the boom swings, the length difference will be distributed over a long length. You'll never notice the difference.
Eric Werkowitz
C25 #4969
Response Posted - 11/30/2003 :  00:36:15  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by eric.werkowitz</i>
<br />I think it's no big deal. While the line may experience some differing in tension as the boom swings, the length difference will be distributed over a long length. You'll never notice the difference.
Eric Werkowitz
C25 #4969
I bet your right.
