 Bottom Job.......again
Mark Maxwell
Initially Posted - 01/24/2002 :  01:49:13  Show Profile
I know this one has been run to death, but this is my current project and I don't want to spend any more time and money than necessary.I've read through the all the past posts on bottom jobs, from prep work to paint types and brands. I must be missing som
Response Posted - 01/24/2002 :  09:03:38  Show Profile
If blisters are not a concern or issue - hit it with 60 or 80 grit (depending on the tool you use) til smooth (or not) and recoat it with something compatible.
Steve Madsen
#2428
OJ(Ode to Joy)
n/a
deleted
Response Posted - 01/24/2002 :  14:59:31  Show Profile
If it is a soft paint, you can only go over it with soft paint. Try to get an idea of what kind it is because the paint you put on must be compatible with the old coating or the whole ting will fail. Vinyls and epoxies don't mix, for example.
Jeff
Response Posted - 01/25/2002 :  01:38:31  Show Profile
When are you planning to launch?
Most bottom paints have a very short life out of the water. When exposed to air they lose their anti-fouling ability. You can prep the bottom and get ready to paint anytime, but for the actual application of the paint
Tim Colbert
Response Posted - 01/25/2002 :  10:15:36  Show Profile
There are bottom paints made where they do not specify a maximum time to launch (ie unlimited). I plan on applying one of these over an epoxy barrier coat.
Cheers
Tim Colbert
79 C25 SR SK #1363
mroettersr
Response Posted - 01/26/2002 :  00:07:33  Show Profile
I have used a West Marine bottom sheild on both my Catalina 22 and 25 with good results in the warm waters of Lake Erie. With the bottom pressure washed at pull-out, one coat in the spring keeps the bottom clear for the season (about 5 - 6 months in the
