 Removing Old Sealant???
n/a
deleted
Initially Posted - 01/27/2002 :  22:16:59  Show Profile
I pulled off all the old teak on my boat now I need to clean the area to reseal. I talked to the previous owner and he said he used a marine silicone sealant. Is there anything that will desolve this to clean the area? Any help on this will be great!
Douglas
Response Posted - 01/28/2002 :  02:40:12  Show Profile  Visit Douglas's Homepage
A good plastic scraper and some MEK. Once a surface has been contaminated by silicone its hard to get rid of it.
teamwike
Response Posted - 01/28/2002 :  08:56:06  Show Profile
I too pulled my teak this weekend. I had a few broken pieces around the companion way. Behind the wood looks like some kind of putty?
I guess this putty was used to seal the back of the wood.
Is this the preferred way to seal behind the back of the wood
Buzz Maring
Response Posted - 01/28/2002 :  14:10:14  Show Profile
I gues
Response Posted - 01/28/2002 :  15:00:41  Show Profile
Here's a great example of why I will never use silicone sealant on anything I know I will have take apart and reseal down the road. Sorry, sharp tools, time and patience are the only formula I know of for removing silicone.
"LifeCaulk" has worked wel
Response Posted - 01/28/2002 :  17:26:00  Show Profile
I've found that after scraping off the bulk pieces, that rubbing with a rough cloth will often "peel off" the residue.
Derek on "This Side Up"
teamwike
Response Posted - 01/28/2002 :  19:58:12  Show Profile
Thanks for the information. It can't be over stated what a great asset this forum is and the people who use it. I also can't believe the wealth of knowledge that can be found at the old forum.
Max in Jaxs
Rick Heaverly 86 C25 5382
Belize
Response Posted - 01/28/2002 :  20:50:07  Show Profile
i removed the teak this past summer. cleaned the area with acetone after using a razor blade scraper. be careful not to chip the gelcoat with the corner of the blade. then used te-ka cleaner on the teak and coated with three coats of cetol. re installed t
