 What new outboard
vandrv
Initially Posted - 01/31/2002 :  19:29:37  Show Profile
I am looking to replace an older Honda 7.5 motor and was wondering what might be the way to go. I am consiering a 9.8 two stroke electric start Nissan. Has anyone had any experience with this motor? The motor mount on my boat states that it can handle 85
Response Posted - 01/31/2002 :  20:29:44  Show Profile
I have an 8hp Nissan electric start and I love it! Just make sure that you get the extra long shaft model!
Derek on "This Side Up"
Shelby
Response Posted - 01/31/2002 :  21:45:08  Show Profile
Derek,
I've been looking at the Honda 9.9 and they have a 15 or 20 shaft length. Why would you get one over the other?
Shelby on "Third S" '82 C25 #3208 SRSR
Steve Raffel
Response Posted - 01/31/2002 :  21:52:34  Show Profile
Look down the list of topics and you'll find Honda vs Yamaha. There are some good postings under that topic.
Steve Raffel
C 250 WK #408
Response Posted - 02/01/2002 :  00:15:22  Show Profile
Shelby - with the standard factory position of the motor mount, a short-shafted motor will cavitate very easily. I used to have a 20" shaft, and in any kind of a chop the prop would spend half its time out of the water. With the 25" shaft I have never had
jm
Response Posted - 02/01/2002 :  12:03:01  Show Profile
to quote rick H. from another thread re: internal halyards (I think), or maybe it was something Duane said last week ?
"i'd rather have a little extra, than be short".
applies to the OB shaft as well. Go for the Honda XLS 25".
Response Posted - 02/01/2002 :  17:06:34  Show Profile  Visit Champipple's Homepage
I think my OB shaft is something like 23 or 24 inches and the ladies love it.
All kidding aside, Get yourself a yard stick and measure the distance from the top of your outboard bracket to the waterline and then some...Be generous....(do this in the
Shelby
Response Posted - 02/01/2002 :  18:42:32  Show Profile
Another question. Because I have to purchase a motor mount (my motor is an inboard right now..and probably going to be replaced soon with an outboard) would anyone recommend the one from Cat Direct as a good one, or is there a better one? Also, how hard
Bristle
Response Posted - 02/01/2002 :  18:58:56  Show Profile
I chose the Honda 8 over the Honda 9.9, Yamaha 8, and Tohatsu(Nissan/Mercury) 9.9 because:
HP--Honda's 8 is the same engine as their 9.9, less a few boat unit$ and a few hundred RPMs that have no meaning on boats like ours.
Alternator--Honda puts ou
andy p
Response Posted - 02/01/2002 :  22:49:24  Show Profile
Is it "cavitation", "ventilation" or something else? The first is the boiling of water in the low pressure area behind a fast spinning prop, causing damage to the blade tips. The second is the condition where a prop is running too close to the surface o
Bristle
Response Posted - 02/02/2002 :  09:14:55  Show Profile
Andy's right... Moreover, if your shaft is short enough that the cooling intake raises out of the water for more than a few seconds at a time (such as when you're on the foredeck with the engine running), the impeller (water pump) can burn out.
Anothe
