I'm having a devil of a time trying to remove the end cap to my boom. I have removed the two set screws and it just will not budge I worry about putting to much pressure on it. What I'm looking for is a description of how the boom and end cap are joined.
My problem is the screw that holds the main sheet bracket to the boom is lose and just keeps turning freely when I try to tighten.
Also just ordered a new foot loose main, is there anything I should know with regard to attaching the clew to the boom.
Jim Meadows "Aloha Friday" (for sale) Sold 1989 Tall Rig - WK Lake Pleasant, AZ
I haven't heard of this problem. The two screws are the only fasteners I've ever encountered. Maybe this is the first time it's been removed and there are burrs holding it? Have you tried placing a block of wood against the end cap and tapping it with a hammer? In the event a PO epoxied it in place you could heat the end cap (not the boom itself) with a blow torch.
Jim wrote... "My problem is the screw that holds the main sheet bracket to the boom is lose and just keeps turning freely when I try to tighten."
Clam asks... Are you talking about the stainless steel "tang" (metal strip) that is screwed to the end of the boom? I believe that's SUPPOSED to be loose enough to rotate. That allows the tang to stay aligned with the mainsheet so the boom doesn't get a twisting force when sheeted out. (At least it was so on my Venture, I've always assumed the C25 is the same).
I believe that's SUPPOSED to be loose enough to rotate. That allows the tang to stay aligned with the mainsheet so the boom doesn't get a twisting force when sheeted out. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
You know you might be right, that makes sense. I never noticed it before, but was on the boat checking the rigging yesterday.
Bruce is right, Jim. The mainsheet tang is supposed to rotate freely. Others have commented that the nut eventually dropped off on their boat, and they ended up replacing the tang by attaching a bail to the end of the boom. However, my 1985's original tang is still attached with no problem.
Which brings us back to the problem of getting the end cap off if you want to. My caps are completely frozen on and the screws won't budge without stipping. I finally gave up for another day. However, a neighbor with a CAT-25 had the same problem and she (doesn't that irk you guys) solved it very simply. She just sawed off the screw heads and then with a little muscle punched the screw threads thru to the inside of boom with a nail punch. Some work with a mallet and the cap came off.
Jim, the others are correct about the bolt needing to be loose. I think there's a nylock nut on it inside the boom. When I had mine apart, I added a jamb nut against the nylock. It would really suck if that fell apart going down wind in heavy air.
As for getting the cap out of the boom, the only fasteners are the obvious screws around the end of the boom. If the boat has been in a salty environment, there could be corrosion between the two parts. You might try letting penetrating oil soak in for a few days, and then apply gentle heat with a propane torch. The suggestion of tapping it with a block of wood is a good one too.
By the way, I suggest you resist any temptation to put a split lockwasher directly under the bolt head or nut. That could act as a ratchet, tighening the threads. If you'd like to add a split washer to quiet any rattling, sandwich it between two flat washers so it can't get a grip on the bolt, nut, or aluminum.
Jim, if this is any help, I currently have both end caps off in my basement and on my 1985 it is just the 2 screws that are holding them on. Once the screws were removed they slid off with no problem. Hopefully this will confirm that at least this is the way it is supposed to be. I have the "tang" on the aft end cap and it swivels with no problem.
I use a loose footed main and love it. I think the secret is to get a "slug" that fits in the slot on the boom correctly (mine has a slug about 3 inches long to help distribute the load and still be able to slide inside the slot. I use a 3:1 purchase on the outhaul, and have a small line running "forward" from the clew so when I want to bag up the main I can release the outhaul and pull on the small line ""in haul"?). I figure the camber ratio on my main can be varied from about 11:1 to 4:1.... Confetti actually sails OK under main alone with the main bagged out to about 4 or 5 to 1!
(I wonder if there is a racing rule on how much you can ease off the outhaul??)
The other skippers have given you good advice on keeping the bolt holding the tang "loose"
Chuck
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> As alway you guys are a big help. One question Chuck, where did you get the 3" slug, I assume the sail does not come with any at that location?
PS. I just added something cool to my boat. I'm in construction and one of my subs had some thin polished granite counter top which he was not going to use. He recut it for me and it looks great on the boat, maybe only added 25 lbs. but hey I don't race. Jim
[/quote] One question Chuck, where did you get the 3" slug, I assume the sail does not come with any at that location? [/quote]
Since I made my own main, I just ended up buying it from Bainbridge. However if you order a loosefooted main it should come with one like the other skippers reported (be sure you tell your sailmaker the size of the boom slot). If you are converting a sail to loosefooted, I bet most sailmakers have them in stock (just too popular an option these days!!!)
