 Anchor Roller installation
Ben
Initially Posted - 03/05/2004 :  07:54:17  Show Profile
Hi All,
I'm going to be installing one of my X-mas presents this weekend, an anchor roller similar to the one in the tech tips section of this website.
http://www.catalina25-250.org/tech/tech25/tt023.html
Anyway, my question is this. In addition to the directions posted by Bill Holcomb in his tech tip, should I put some kind of bedding compound between the anchor roller and the deck? If so, what is a good product to use? It seems to me that there should be something there to serve a gasket function.
Any thoughts?
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
lcharlot
Antigua and Barbuda
Response Posted - 03/05/2004 :  08:24:27  Show Profile
Bed the roller bracket with 3M-5200 or Boat Life Polysulfide, same as any other deck hardware. Yor need to seal the bolt holes so that water doesn't wick down the bolts and rot the deck core.
Waterboy
Response Posted - 03/05/2004 :  10:09:44  Show Profile  Visit Waterboy's Homepage
Ben,
My I ask what size/type of roller you're installing? Also, what type and weight of anchor(s) are you using and how you intend to store them?
Thanks!
Ben
Response Posted - 03/05/2004 :  10:28:44  Show Profile
Thanks for the tip, Larry.
Waterboy, I plan on storing my anchor with this from West Marine.
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=4547
The kind of anchor roller is pretty much a duplicate of the one in the tech tip, but I didn't get it from WM. The type of anchor I'm using is a Danforth. I don't know what size exactly, but I'm sure it's the typical anchor for the C25. It fits nicely in the anchor locker.
Ed Montague
Response Posted - 03/05/2004 :  11:44:25  Show Profile
I haven't read Bill's discription so if this is a duplication I apologize. Ben, before you drill anything, place the anchor you will be using into the bow roller and then put the assembly in place to check for clearances and position. You want the anchor comfortably cradled in the bow roller but not hitting the gel coat with the pointy ends. I would be afraid to just mount the roller and then find the anchor won't hang correctly. Just a thought.
JimB517
Response Posted - 03/05/2004 :  12:47:17  Show Profile  Visit JimB517's Homepage
make sure the anchor stock fits under the roller drum (if you have one). Very tight fit on Indiscipline III, I had to move the drum up 2 inches.
Ben
Response Posted - 03/05/2004 :  13:24:59  Show Profile
Thanks for the tip, Ed. I don't think my anchor will work like yours. I think yours is a plow-type anchor, while mine is called a Danforth, I think. It is shaped totally differently and I don't think will fit in the anchor roller like yours. That's why I'm going to hang it from the bow pulpit with that item referenced in the West Marine link.
Ben
Response Posted - 03/05/2004 :  13:26:20  Show Profile
Hi Jim, Unfortunately, or fortunately (not sure which I would prefer) I don't have a roller furling. Simply hank-on. Thanks for the heads-up though.
Ed Montague
Response Posted - 03/05/2004 :  13:36:32  Show Profile
Ben, My anchor is a Bruce style clone, 16.5 lb. I have a Danforth as my secondary and can hang it like you plan. I have had good luck with the Bruce. I pinched my fingers handling the Danforth one time too many and decided to go with a non-pincher style as the primary. Anchoring is important even if you don't overnight or cruise. When the wind and motor both fail and the shore is too near for comfort, a good anchor easily set out can save the day.
Ben
Response Posted - 03/05/2004 :  14:49:16  Show Profile
I agree Ed, and I'd like a new Bruce. But I'm a cheapskate and can't afford it. My cruising grounds, however, are small and not suseptible to heavy seas. My anchorage nine times out of ten is a protected inlet or bay.
