 teak cleaner
cmckitrick
Initially Posted - 03/10/2004 :  10:43:16  Show Profile
I know the topic of teak evokes many opinions which is what I am looking for. I am restoring the exterior teak of my '82 Catalina 25. I have sanded all I could. I am wondering if I should still use a teak cleaner and if so what? I have read that some of the two part cleaners are too harsh. Any suggestions? When I get to the interior do people recommend completely sanding it down? I am alos wondering about gloss vs. satin for the outside.
Thanks.
Charlie McKitrick
Norwell, MA
Valiant Lady... for now
'81 C 25 SR/FK
cmckitrick
Response Posted - 03/10/2004 :  13:30:31  Show Profile
I guess this was not as hot a topic as I thought.
Response Posted - 03/10/2004 :  13:52:28  Show Profile
Sorry you didn't get a response. Sometimes it takes a day before someone gets around to replying.
IF you'll click on these two hyperlinks, they will take you to recent, exhaustive discussions of interior teak. After you have sanded your teak, you probably don't need to use a teak cleaner. Whether you use gloss or satin on your exterior teak is purely a matter of personal preference. Which looks better to you? The best thing I have ever done for my teak is to make covers for the exterior teak. Covers protect it from the sun and water when you're not using the boat, and it makes your maintenance <u>much</u> easier.
http://catalina25-250.org/forum/topic.asp?TOPIC_ID=5352& SearchTerms=interior teak
http://catalina25-250.org/forum/topic.asp?TOPIC_ID=5905& SearchTerms=interior teak
TomA
Response Posted - 03/10/2004 :  17:06:47  Show Profile
I agree with Steve, that you probably don't need a teak cleaner after sanding. However, if some stains or oils remain, I have found that a little TSP (trisodiumphosphate) dissolved in water can work wonders on your external teak. You can buy it at most hardware stores.
Good luck!
Tom
Response Posted - 03/10/2004 :  17:09:53  Show Profile
Just a heads up - with some chemical cleaners, if it is allowed to run down onto the windows, it can damage the aluminum window frames anodized finish.
Edited by - OJ on 03/10/2004 17:52:45
rford
Response Posted - 03/10/2004 :  17:31:18  Show Profile
What's the recommended process for exterior teak?
oldsalt
Response Posted - 03/10/2004 :  18:56:01  Show Profile
You have to be careful with teak cleaners since if allowed to run down on your aluminum windows, if not washed off immediately, they will irrepairably stain them. Marine teak cleaners will also remove the pulp in your teak.
If you want to brighten (bleach) your teak, Starbrite teak brightener will do the trick, but I would stay away from the cleaners since they will ultimately damage your teak as you scrub it down.
Response Posted - 03/10/2004 :  19:02:16  Show Profile
Also, keep the sanding of your teak to a bare minimum. After a few years, it weakens them significantly, and those rascals are fairly expensive to replace.
John J.
Response Posted - 03/10/2004 :  19:05:36  Show Profile
I think Iv'e tried just about everything on exrerior teak. If the wood doesn't need to be stripped due to remnants of a hardened finish like varnish, Iv'e had great success with either Te-Ka or Teak Wonder. Te-Ka is the fastest but you need to have a hose and fresh water ready because the runoff can stain fiberglass. Teak Wonder won't. If your wood is just silvered from the effects of the sun, both of these products will restore the natural color easily. I don't rcommend bleach because it washes out the beautiful natural color of the teak. After that , do a little sanding, and you're back to almost new. Most folks seem to prefer Cetol because of the ease of maintenance, but I don't like the way it looks. Beauty is in the eye of the beerholder as they say. Last year I removed most of the exterior teak and applied 8 coats of marine varnish . A really great reference is a book called "Brightwork" bt Rebecca Whitman. I wouldn't recommend the varnishing route unless you 're queer for wood like I am and enjoy the process!
cmckitrick
Response Posted - 03/11/2004 :  08:26:21  Show Profile
Thanks everyone for your helpful answers. John, I am going the varnishing route because I am "queer for wood". I don't care how much work it takes (of course I say that now, I havent done it yet). As a fellow boat owner told me about brightwork, the beauty of the end result is directly proportional to the work you put into it.
