 OK so Spike is going up the mast
Response Posted - 03/12/2004 :  06:17:09  Show Profile  Visit Champipple's Homepage
<br />If my experience is any help, the space at the masthead over the top of the sheaves will NOT allow a 3/8" line attached to another halyard to be pulled through from the deck. It doesn't matter how you "tie" them together, you can't get it thin enough. It took quite some effort on the part of my crewman, using a screwdriver, to "persuade" the 5/16" line to feed through - and Jim is using 3/8"!!
Derek
But you don't have to thread the 5/16th's into place...only the end with the 3/16ths
Response Posted - 03/12/2004 :  08:25:41  Show Profile
I had no problems threading my 5/16" halyards through the masthead and they move very smoothly over the sheaves.
Response Posted - 03/12/2004 :  10:47:20  Show Profile
"But you don't have to thread the 5/16th's into place...only the end with the 3/16ths"
With all due respect Dave, the 3/16" ends should have shackles eye spliced into them...at least, they should if you want a neat looking job rather than a bulky bowline.
Don L. - that's interesting. You must have more space up there than I did, because it was a struggle to get my 5/16" through. Do you have all rope sheaves? I kept the original (well, a year old) wire sheaves because the 3/16" fits in them without binding.
Derek
Response Posted - 03/12/2004 :  12:36:24  Show Profile
<br />...Don L. - that's interesting. You must have more space up there than I did, because it was a struggle to get my 5/16" through.
Do you have all rope sheaves?...Derek<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Do I have all rope sheaves?...Yes and no...I have the all rope sheaves, but they currently reside in my parts box.
When I converted to all rope halyards I ordered the older CD 1/4" replacement sheaves, but I wasn't satisfied with the fit so I used the existing wire rope sheaves because they worked better than the new sheaves. My existing wire rope sheaves have a V-shaped design with a slot at the bottom of the V for the old wire rope. My 5/16" halyards ride in the V like groove above the wire rope slot similar to how a car fan belt rides on a pulley. Since the halyards don't ride directly on the bottom of the sheave I do get a little dent from the narrow wire rope slot(jib halyard stays up all season), but it doesn't appear to be causing a problem with the halyard.
Before commiting to this arrangement, with the mast down I put the new halyards under strain and observed their operation with the wire rope sheaves and they worked fine. After two years , both halyards continue to operate very smoothly and without problems.
(PS...I still have the new never used older CD 1/4" sheaves if anyone wants them...FREE...They would work fine with 1/4" or less line, but because of their smaller diameter, you may have to file down the masthead truck to prevent the halyard from chafing)
Edited by - dlucier on 03/12/2004 12:38:27
