 Swing keel maintenance
John J.
Initially Posted - 03/13/2004 :  16:43:33  Show Profile
I'm sure this topic has been covered "ad nauseum" on this forum, but I'm in need of your advice. I plan on doing the swing keel maintenance thing this year, ( cable, ball, winch,). Have never done it before. Boat is now in the water. I know nothing about this procedure. Any comments appreciated.
1987 C 27
#6387
Steve Kostanich
Response Posted - 03/13/2004 :  16:47:24  Show Profile
John,
You are right, check the archives one this subject. Tons of stuff there. I would also change the cabe fixture on the keel and the hanger brackets and pivot pin while you have evrything apart.
Steve Kostanich
Buzz Maring
Response Posted - 03/13/2004 :  19:34:31  Show Profile
Hi John,
I found these three threads in the archives that should be some help to you ... good luck!
[url="http://www.catalina25-250.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=1248&SearchTerms=cable"]Swing keel cable replacement[/url]
[url="http://www.catalina25-250.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=3027&SearchTerms=cable"]Swing keel cable replacement[/url]
[url="http://www.catalina25-250.org/forum/topic.asp?ARCHIVE=true&TOPIC_ID=3108&SearchTerms=cable"]Swing keel cable replacement[/url]
