 Sealing ports
steephen
Initially Posted - 03/23/2004 :  15:59:11  Show Profile
Stephen Z here again.
Time to repair those leaky windows. I have heard that Boat Life was a good product because it isn't actually an adhesive (I'm talking about between the outside aluminum flange, and the outside fiberglass). Then I was told about simple pure clear (100%) silicon from the hardware store, for basicially the same reasons but a third the price. Any opinions?
Second, there's some delamination in the wood core between inner and outer fiberglass, usually hidden by the window flanges. The two-part epoxy they sell to flood this does not look like it's going to like going in upside-down. Any other, less fluid, products to recommend? How much of the delaminated ply should I bother to carve out of there?
Thanks again.
"Little Wing" C-25, 1980
Ed Montague
Response Posted - 03/23/2004 :  16:29:19  Show Profile
Stephen, There is a better solution to sealing the windows then the heavy silicon you can get from the hardware store. Go instead to your local automotive supply house and purchase a specifically designed silicon sealer made for leaking windows in RVs. It comes in a small tube and very fluid so that it will penetrate the leaky window gaskets. Just run a bead around the window, no mess. Somebody else will probably be able to jump in here and give you the exact name. You can use it either between the glass and the frame or the frame and the fiberglass. This stuff really makes sealing the leaks simple.
steephen
Response Posted - 03/23/2004 :  19:16:55  Show Profile
Ed:
Thanks. Hopefully someone will know the name of the other stuff. I've already pulled the aluminum flanges off, so I will end up putting Boat Life or silicon between the fiberglass and the flange before re-installing. I'd like to use the stuff you mentioned to seal up the tiny beading between the glass and the aluminum (on the outside of each window).
Still seek advice on the wood delamination between the fiberglass walls around each window.
Thanks again to all.
Little Wing (#1667)
Buzz Maring
Response Posted - 03/24/2004 :  10:27:45  Show Profile
<font color="blue">Hopefully someone will know the name of the other stuff. I've already pulled the aluminum flanges off, so I will end up putting Boat Life or silicon between the fiberglass and the flange before re-installing. I'd like to use the stuff you mentioned to seal up the tiny beading between the glass and the aluminum (on the outside of each window). - Stephen</font id="blue">
Hi Stephen,
I've used "Permatex Auto Glass Sealer" ... it is just like Ed described ... it wicks into the space around the frame and does a good job of sealing small leaks with minimal effort. You can find it at any auto parts store, and I also bought a tube at WalMart.
BTW, when I rebedded my windows, I used a silicon sealer around the aluminum frames. Someone once suggested using a sort of "putty tape" instead ('don't know what else to call it). I haven't found that thread, but as I recall this sealing "tape" is also found at auto parts stores and RV supply houses. If I ever rebed my windows again, I'm going to look for that "tape."
'Hope that helps ... good luck!
Response Posted - 03/24/2004 :  13:06:00  Show Profile  Visit Leon Sisson's Homepage
Buzz & other leaky port sufferers,<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">...sort of "putty tape" ... found at auto parts stores and RV supply houses.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">That's what I used, and it has worked great. It's similar to kids' modeling clay, but stronger and stickier. It came in a roll layered between wax paper, like two-sided tape. The stuff was dirt cheap, and seemed to be such a generic commodity that there wasn't even a brand name on it. One of the big advantages (besides keeping water out) is that the port assembly can be removed in the future without much risk of damaging it.
P.S. Edited in response to "<b><i>...bubble gum from your shoe...</i></b>" comments. There might well be more than one tape-like product out there. I've had several of my ports back out, and the RV putty tape I used wasn't much more messy to clean up than oil-based modeling clay. It was a whole lot easier to remove than any marine sealant I've ever squeezed out of a tube (or cussed at with a razor scraper in my fist). --L.S.
Edited by - Leon Sisson on 03/24/2004 15:59:48
Response Posted - 03/24/2004 :  13:41:25  Show Profile
I think the PO used this stuff on the windows of my boat, and when I was cleaning up the frames during a rebed, this stuff was like removing bublegum from your shoe.
Response Posted - 03/24/2004 :  13:47:02  Show Profile
I agree with Don's quote. I had exactly the same experience and I definitely wouldn't use it!
Derek
John Mason
Response Posted - 03/24/2004 :  15:31:11  Show Profile
BoatLife LifeSeal is an adhesive. It's part polyurethane/part silicone - the benefit is that it can be used on plastics. LifeCaulk is also an adhesive. It's polysulfide.
