 Swing Keel Cable Replacement
albert
Initially Posted - 03/30/2004 :  21:55:52  Show Profile  Visit albert's Homepage
I'm getting ready to replace my keel cable. I'm planning on purchasing 7 x 19 strand 1/4" cable by 10 feet and attaching a swageless fitting at the end. From what I've read regarding cable failure, it appears that the cable pulls out of the swaged fittings. Swageless fittings should prevent this. (BTW, I've checked and they work with 7x19 strand).
See article describing benefits of swageless at http://bosunsupplies.com/GoodOldBoatQuickAttach.CFM
Any ideas what the end fitting looks like?
Is it an "eye terminal" Suncor brand http://bosunsupplies.com/products2.cfm?product=S0761
or
a "forked terminal" Suncor brand http://bosunsupplies.com/products2.cfm?product=S0762
See also Sta-lok brand: http://www.stalok.com/parts.asp?family=1xImperial
Constructive criticism is welcome. I'd rather make and correct the mistake on "paper".
Albert Iturrey
al@comhertz.com
Abacus 1984 C25 #4679
Edited by - albert on 03/31/2004 00:27:07
Steve Kostanich
Response Posted - 03/30/2004 :  23:19:05  Show Profile
Albert,
DO NOT use 1X19 for a keel cable, it is in no way flexible enough for the job. You want 7x19. 1X19 is for standing rigging.
Steve Kostanich C-25 Equinox 1119 sr/sk
albert
Response Posted - 03/31/2004 :  00:09:16  Show Profile  Visit albert's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Steve Kostanich</i>
<br />Albert,
Missed that! Thanks. I've corrected it in the original post.
Response Posted - 03/31/2004 :  01:00:11  Show Profile  Visit Leon Sisson's Homepage
albert,<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Any ideas what the [stock cable] end fitting looks like? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">The swing keel cables I've been getting from Catalina Yachts come with a swaged fork end. The original attachment point at the keel was a one-piece eye-bolt (3/8"ID, 1/2-NC in keel). The upgraded 3-piece keel attachment hardware has a fork wide enough to straddle the Catalina Yachts swaged fork cable terminal.
Good luck, and please let us know how it goes!
Response Posted - 03/31/2004 :  09:38:23  Show Profile
I wonder if moving up to 5/16" cable would work... (my guess is yes).
Unless I do the wing conversion next fall, I'll give it a go myself.
Lindsey51801
Response Posted - 04/12/2004 :  15:18:31  Show Profile
Hi Everyone,
Just thought I would leave some input regarding the keel cable and swaged end fork fitting. The reason a lot of keel cables break at the connection point of the swaged fitting is if the boat is on a mooring and the keel is in the down position, and if there is any slack in the cable the keel will keep moving and twisting at the fork which is why is can sheer it right off or even pull it out of the fork fitting. Anyway, just thought I would give a little advice.
Happy Sailing,
Lindsey
Happy D
Response Posted - 04/12/2004 :  19:20:28  Show Profile
Funny you should ask Albert. I was running the exact same idea through my head today. I pulled my keel cable out yesterday. The fork opening is 5/16" wide. Depth of the fork opening is 1 1/2" from the end of the fork to the bottom of the throat. Cable Dia. is 1/4" 7x19. The pin is 3/8" x 1"long.
I noticed the new cable is $49.95 from CD. Tried to order it today but they were closed.
If you need to see anything else, let me know, the cable is laying on the work bench.
Dan
Scotd
Response Posted - 04/12/2004 :  20:00:50  Show Profile  Visit Scotd's Homepage
I just ordered the Keel Cable and Keel Ball from The Anchorage, Lyons Colorado.
http://www.marina42.net/cgi-bin/p/m42p-home.cgi?d=the-anchorage
Cost $54.33 including Shipping.
Response Posted - 04/12/2004 :  20:34:49  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Scotd</i>
<br />I just ordered the Keel Cable and Keel Ball from The Anchorage, Lyons Colorado.
I came within hours of buying a boat from The Anchorage, they were wonderful people to deal with. Your price reminds us all that Catalina Direct DBA The Foredeck is really nothing more than a very well run Catalina dealer and the prices on many things are very similar to local dealer pricing.
Mark Loyacano
Response Posted - 04/13/2004 :  00:15:11  Show Profile
While changing cables, have you given any thought to upgrading to the new style keel lifting bracket?
albert
Response Posted - 04/13/2004 :  00:53:33  Show Profile  Visit albert's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mark Loyacano</i>
<br />While changing cables, have you given any thought to upgrading to the new style keel lifting bracket?
I plan to change it also. How hard do you think it'll be to remove the old one?
albert
Response Posted - 04/13/2004 :  01:02:27  Show Profile  Visit albert's Homepage
While reading up on different grades of stainless steel, I learned that to prevent rust stainless needs oxygen. There's little oxygen available to the stainless keel fittings underwater; therefore, they rust, then fail. Starts in small cracks. Sounds like the type of end fitting is not the <u>cause</u> of the real problem. The problem is the lack of oxygen needed by the stainless steel to fight rust.
I keep my boat in seawater with the keel in the retracted position. I've got shorepower. I was wondering if I could just connect an aquarium "airstone" to an aquarium air pump to feed oxygen to the underwater stainless steel. Problem: how to run the small air stone and hose so that it spills its bubble stream over the end fittings...?
BTW, how much of the stainless is underwater when the keel is retracted?
Response Posted - 04/13/2004 :  10:16:21  Show Profile
IMHO follows... (perhaps slightly more than IMHO)
"There's little oxygen available to the stainless keel fittings underwater"
There's plenty of oxygen in most bodies of water. (unless you see dead fish floating around)
My (good quality) underwater 316 stainless is shiny and bright. The corrosion problem occurs down INSIDE the crimped fitting (or cable itself) where there is little opportunity for O2 exchange/renewal. (stagnant) Your air bubbler probably won't do any good... the oxygenated water can't get in there to renew the O2 supply.
One of the advantages of the Sta-lok style terminals is that you can fill the inside of the terminal with sealant to keep water out in the first place.
"Starts in small cracks"
Absolutely correct. Cracks form a point of attack for the ions in the seawater.
My belief is that if the stock fitting is over-crimped it produces micro-cracks in the stainless cable strands. This provides a starting point for the corrosion. It may also be the explanation for the posts that go something like..."the original keel cable lasted XX years... the replacement failed in 8 months in the same body of water on the same boat".
Full IMHO turned on... I think that the last paragraph summarizes what often happens in these failures.
Mark Loyacano
Response Posted - 04/13/2004 :  10:41:59  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by albert</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mark Loyacano</i>
It isn't too hard, Albert. If the old eyebolt doesn't want to turn after applying reasonable effort, apply heat to the area. I used a small propane torch. The new style lifting bracket will not fit into the same area without removing a little material. I used a hack saw and cleaned things up with a grinder. It was a messy job, as I recall.The new keel bracket will come with instructions for proper installation.
albert
Response Posted - 04/14/2004 :  01:24:32  Show Profile  Visit albert's Homepage
I guess that my original idea to use a swageless fitting should work.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I used a hack saw and cleaned things up with a grinder. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Would a Dremel cutting wheel work?
Edited by - albert on 04/14/2004 01:27:02
Mark Loyacano
Response Posted - 04/14/2004 :  09:27:45  Show Profile
You can try a Dremel wheel, Albert. If it doesn't work you'll soon know it. That "iron" keel is really tough. My grinding wheel was attached to an air driven drill. If the dremel isn't working just use a small grinding stone attached to your drill.
Shave a little ... fit the bracket...shave a little more...stop when it looks well seated. When the bolt is installed, the bracket (and bolt head) needs to sit flat. The instructions will tell you about torque and thread locker.
Response Posted - 04/14/2004 :  19:02:00  Show Profile  Visit Frank Hopper's Homepage
For what it is worth... I bought a new fitting but when the old one was unwilling to budge I decided that if it ain't broke don't fix it. My bracket awaits another day.
Scotd
Response Posted - 04/14/2004 :  21:11:17  Show Profile  Visit Scotd's Homepage
I got my parts today, ohhhhhh so shiny and new.
Mark Loyacano
Response Posted - 04/14/2004 :  21:21:44  Show Profile
<br />For what it is worth... I bought a new fitting but when the old one was unwilling to budge I decided that if it ain't broke don't fix it. My bracket awaits another day.
It is hard to imagine what the old fitting was torqued to or worse, what sealant or thread locker was used. Mine was installed with "red" Permatex thread locker. It required substantial heat to release it. I used a different kind going back in.
Response Posted - 04/14/2004 :  21:35:25  Show Profile  Visit Frank Hopper's Homepage
Mark, when a breaker bar didn't work I chickened out.
Albert, I replaced the cable and ball recently and my ball did not hav e the double pin you have.
I hope you got the new hose and new clamps from CD, they are important.
Have you looked here
http://homepage.mac.com/fhopper/PhotoAlbum36.html
Mark Loyacano
Response Posted - 04/14/2004 :  22:55:48  Show Profile
<br />I hope you got the new hose and new clamps from CD, they are important.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I used a new heavy duty radiator hose, silicone around the base (inside the hose and on the outside of the "to hull") and double stainless clamps. It was just the right size diameter. No leaks in several years. To remove it (to inspect the ball and pin) just grab it with both hands and twist hard...pops right off).
Response Posted - 04/14/2004 :  23:08:38  Show Profile
Mark wrote..."red" Permatex thread locker. It required substantial heat to release it. I used a different kind going back in."
The new style keel fitting has a locking pin that prevents the bolt from backing out... so I put never-seize on my threads. Should be easy the next time.
albert
Response Posted - 04/15/2004 :  02:48:14  Show Profile  Visit albert's Homepage
I'm considering replacing the winch, but someone recently wrote that <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">the fitting for the winch handle on the original was sort of recessd in the vertical part of the steps. The new one sticks out about an inch and a half from the vertical part of the step. So, we cut a hole in a tennis ball and slip it on to save scraping one's leg.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Has anyone else encountered this?
If the above is true for all replacement winches (catalina yachts vs catalina direct, etc), I think I'll baking soda blast, clean, paint, and rebuild the original winch.
Happy D
Response Posted - 04/15/2004 :  06:05:44  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> I got my parts today, ohhhhhh so shiny and new<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I can't even get the local marina to call me back so I can order the cable and ball.
Response Posted - 04/15/2004 :  10:08:37  Show Profile
"I think I'll baking soda blast, clean, paint, and rebuild the original winch."
When you dismantle the winch, you'll find that there's not much that can go wrong with it. I 'overhauled' (cleaned/painted/lubricated) mine and I think it's good to go for another 25 years. Not like they get enough 'mileage' to really wear 'em out.
Now, if they'd just galvanized them at the factory... well I guess that's not a good idea from their point of view, they wouldn't be selling any replacements.
Scotd
Response Posted - 04/15/2004 :  10:22:46  Show Profile  Visit Scotd's Homepage
Does anyone know about the double pin with the keel ball? The old one was a single Pin??
