 Help Pulling Wires Thru Mast
frich
Initially Posted - 04/04/2004 :  16:55:18  Show Profile  Visit frich's Homepage
I have begun my mast wiring project, bought 100ft roll of marine grade wire on Ebay $22.
I was planning to pull the old wire out, while attaching a pull string to (1) end, this way I can pull the new wire thru. However no matter if I pull at the mast head or foot the old wire will not move (and yes I diconnected my lights). Did Catalina secure this wire some how? If I remove the masthead would it be easier? And if so how does this come off.
As always I appreciate the insight offered.
FrankR
84 C25 SK
Edited by - frich on 04/04/2004 17:51:28
Response Posted - 04/04/2004 :  17:53:50  Show Profile
Hi Frank,
Does your mast have an internal conduit?
Maybe you could grab the steaming light wire with a pair of needle nose pliers . . . after you remove that wire - it might loosen-up the others.
The masthead should be held in place with a couple of screws.
Edited by - OJ on 04/04/2004 17:55:18
frich
Response Posted - 04/04/2004 :  19:27:14  Show Profile  Visit frich's Homepage
No I dont believe i have an internal conduit. I will try pulling on the steaming light wires first though.
albert
Response Posted - 04/05/2004 :  00:49:16  Show Profile  Visit albert's Homepage
Pull a couple of 80lb test fishing line also. That way if you need to run wire in the future you'll have a way of doing it.
albert
Response Posted - 04/05/2004 :  00:49:17  Show Profile  Visit albert's Homepage
Response Posted - 04/05/2004 :  08:07:40  Show Profile  Visit Champipple's Homepage
Catalina stuffed foam in the mast to keep things from rattling, it might impede pulling the wire through. I agree with albert, you should always have a line running through for future needs. Also, make sure your steaming light is disconnected too. I beleieve it was the same wire as the masthead.
dw
Response Posted - 04/05/2004 :  11:49:22  Show Profile
When we rewired the mast last year (without dropping the mast) the new wire would not pull through all the way. The old foam "packing" pulled down and jammed. We packed old towels around the mast step and poured a pint of acetone down the mast using a small funnel - problem solved!
Derek
frich
Response Posted - 04/05/2004 :  12:35:07  Show Profile  Visit frich's Homepage
As usual you guys have the answers, I thought there was something impeding my pulling the wire through.
Frank R
eric.werkowitz
Response Posted - 04/05/2004 :  19:22:48  Show Profile
I used my forestay as a snake to help fish some parachute cord through the mast when I installed conduit and rewired. Then I ran the ends of the cord through the conduit when I slipped it into the mast. The cord was plenty strong to pull the wires.
You may want to consider putting the conduit in the mast while you're doing the job.
Phredde
Response Posted - 04/06/2004 :  20:37:17  Show Profile
I used the forestay trick too, but I duct taped the wire to the lead end of the forestay and was able to jam it through. Good luck.
