 Anchor Light
Rollins
Initially Posted - 04/15/2004 :  23:36:36  Show Profile
Don't you hate forgetting things
I checked and double checked everything (I thought) before launching Wind Walker yesterday. Minor issues are so much easier to handle on the cradle! But after rigging the boat post-launch in the slip, it dawned on me to check the lights. Naturally, the one that does not work in the anchor light at the top of the mast. I haven't fully investigated yet. Are there things to check before going up? I have never seen anyone use a bosun chair; how much fun is that? Is there some info on general safety tips?
Any advice appreciated. Not sure I have the guts to ride up the mast in the chair anyway. May have to coax a willing dare-devil at the marina, if I can find one.
Thanks in advance,
Mike R
Wind Walker 1989 SR/WK #5947
Response Posted - 04/15/2004 :  23:48:12  Show Profile
How much do you weigh?
I don't know what it takes to dump a C25... but I'd be leery of going to the masthead with more than 200 lbs. (or so).
I'd be inclined to lower the mast for a problem like this. Often mast lighting issues are due to a pinched wire at the mast foot. It would be discouraging to hang around up there for awhile and find out the problem was down at the bottom.
Response Posted - 04/15/2004 :  23:48:55  Show Profile
Maybe you can ask Spike, the C25/250 National Association website editor, to check out your anchor light!
Response Posted - 04/15/2004 :  23:58:22  Show Profile
Mike,
If you don't have a meter, go to Sear's and buy a $10.00 meter that will read volts and ohms, then check to make sure you are getting voltage at the deck connector. If you have voltage at the connector, then check continuity (resistance) between the ground wire going up the mast and the wire that is going to the anchor light. You should read almost no resistance if the wiring and bulb are good. If the meter indicates an open (very high resistance) then you either have a burnt bulb or an open in the wiring.
If you go and buy a meter, you might want to spend the extra $5.00 and get a digital meter with an audible continuity check. It makes troubleshooting easier.
Edited by - dlucier on 04/16/2004 00:08:24
Response Posted - 04/16/2004 :  08:44:05  Show Profile  Visit Champipple's Homepage
Generally I'd recommend dropping the mast before going up in a chair. Especially because your in a boat that has a deck step mast and is built for raising and lowering often… In short, even though you probably don’t think so, its easy to do in relation to other boats.
My second suggestion is to go up in a mast hoist if your location has one for stepping the mast on larger boats.
If you really have to go up in a bosuns chair I recommend the following –
<li>Before going up, inspect all shrouds and stays and then double all your docklines and remove all of the slack you can. Also add a fore and aft springline</li>
<li>A minimum of two halyards attached to you – one to carry the load, the other as a safety line. If you only have a main and jib halyard – go up on the jib side of the mast and use the main as an emergency</li>
<li>If you have a clutch cleat (spinlock) that allows your halyard to move in one direction, lock it and use it.</li>
<li>Do not use shackles or hasps, tie bowlines to the chair with the lines. If your shackles are spliced into your halyards and you are unable to tie bowlines with the line tape the release pins or clevis pins on the hasps closed.</li>
<li> Ideally have 2 people on the ground – on the hoist, one can tail the line off the winch, once up they can be a gopher. Always have one person stay with the boat</li>
<li>Once up, double cleat your line, or tie a hitch (counter clockwise) around the winch after the clutch cleat</li>
<li> Attach a bucket to your spare halyard to send up anything you might need – remember to use the lanyards on tools that have them.</li>
<li>work quickly</li>
<li> Help the person winching you up by climbing the mast</li>
<li> Take up 2 or three spare bulbs </li>
Hope these help
dw
Response Posted - 04/16/2004 :  10:23:56  Show Profile  Visit Frank Hopper's Homepage
Go to sailnet, buy the Davis utility megalight for a few dollars. It is a better anchor light anyway. Go sailing. Worry about it next time you are on the hard. UNLESS you need it to illuminate your Windex, then drop it and FIX IT.
Response Posted - 04/16/2004 :  11:36:58  Show Profile
I would still check the circuit before either going up or dropping the mast because a lot of problems happen around the deck plug.
Buzz Maring
Response Posted - 04/16/2004 :  13:45:04  Show Profile
<font color="blue">I would still check the circuit before either going up or dropping the mast because a lot of problems happen around the deck plug. - Don</font id="blue">
I have to agree. I'm guilty of having taken my mast down once to replace the bulb, only to find out that the bulb was OK and the connection at the base of the mast was bad ... that was a lot of work for nothing
falco_esq
Response Posted - 04/16/2004 :  13:53:43  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rollins</i>
<br />Don't you hate forgetting things
I have the same problem, but luckily the mast is still down. Let me know if you figure it out!!
Thanks in advance,
Mike R
Gloss
Response Posted - 04/16/2004 :  16:55:47  Show Profile
As usual, Don is right on. Buy a digital meter with a continuity tester. However I had two Sears meters go out on me in one year. Cheap Chinese crap. I finally bought an Ancor meter. don't know where it's made, but it hasn't failed yet.
and if you need some pointers on using the meter, buy don Casey's book "Sailboat electrics Simplified" you will be glad you did.
Good luck
Response Posted - 04/16/2004 :  20:00:10  Show Profile
Fluke produces an excellent line of meters and other electrical instruments.
How can you resist buying from a company with the slogan...
"If it works, It's a Fluke".
Ed Montague
Response Posted - 04/17/2004 :  22:36:49  Show Profile
Bruce, I have a Fluke, but it cost substancially more then $15. A few years ago it cost well over 1 boat unit. I agree, buy the meter and check everything you can from the base of the mast first.
Rollins
Response Posted - 04/18/2004 :  17:51:46  Show Profile
As usual, tons of great advice. Good point on checking with a meter first. I'll check that out next trip to the lake.
Sounds like avoiding the use of a bosun's chair is the consensus of the group. I'll try all the other options first. Then maybe its time for me to learn to take the mast down. Gotta learn sometime, right?
Thanks again. I'm sure I've said it before, but being a member of this forum is one of the best things about owning a Catalina 25. You guys are great!!!!
Mike Rollins
1989 SR/WK #5947
