Just a reminder for those who have not stepped the mast to check the mast truck pins. My pins on the fore and aft stay are so corroded that they had to be cut and drilled out. The corrosion will lead to destructive pressures inside the alloy casting resulting in the truck cracking....or worse. Now mine are loose and lubriplated.
You are right is is the masthead casting. If you find your pins are stuck in place you have 2 options-leave them untill they crack the casting or drill them out. my pins drilled out pretty easily. I first cut the ends off with a high speed cutter and then cut the center out with the cutter. If it were the halyard pins it would have been a little different story. Here is a link to a picture.
I tried to get my mast truck off last year and failed miserably. The screws that are holding it are frozen in place. Any suggestion for getting them out?
Dave Gabel Walkure Sail 1484 1979 Tall rig, fin keel
Kroil... PB Blaster. Let it soak. Maybe a little tiny bit of heat to encourage oil penetration and seperate the junctions. (not much heat on aluminum). Impact driver if you have one.
You should be able to drill out the stainless screws and oversize them if needed. I will be paying closer attention to the whole stainless/aluminum issue in the future.
I just removed my masthead to install new wiring. I gave the screws a little tap to shock them, soaked them in WD40 fo a few minutes and then used channel locks to break them loose. Then went to West Marine a nd bought replacement screws.
