 doyle sails
Brooke Willson
Initially Posted - 05/02/2004 :  07:29:06  Show Profile
OK, folks, after much research and your mixed opinions, I've decided to buy a new main with two full top battens and two partial lowers. Having installed a 36(h) x 48(l) x 80(w) bimini on genoa track slides, having moved my mainsheet to just aft of the companionway, the new measurement of the main calls for a 26'6" luff to clear the bimini. That means a Capri 25 main will fit exactly. yes, I will order loose footed.
The Doyle sails advertised through catalinaowners.com are a great price. Have any of you bought these sails? What did you think?
Thanks.
Brooke
"Even Chance" 1985 SKTR # 5050
Urbanna, VA
Response Posted - 05/02/2004 :  11:02:34  Show Profile
A buddy has Doyle sails on his Mac 26C... seem like really nice sails to me. They are one of the largest sailmakers in the world and have been around for a long time.
I think with new technology (computer-generated designs, laser-cutting, & etc) a lot of the 'mystique' has gone out of sailmaking.
LeighMarie
Response Posted - 05/02/2004 :  11:23:33  Show Profile
I just received my brand new Doyle mainsail this past Thursday. I put the boat in the water yesterday but was not able to put the sail on yet, but I'm sure I will love the sail. I bought a Doyle 150 genoa 2 years ago and have loved it. I looked at a number of other types of sails (North Sails, UK, etc.) but I really like the Doyle sails. I also respect the loft I work with as they have been very helpful also. Service is important.
I got 2 top full battens and 2 lower partial battens. I also got a draft stripe put on, just for the fun of it! I replaced the original mainsail with it, and the new sail actually is a bit taller and it is larger at the roach than my original one. I'll be anxious to see how it actually fits when I get it on.
Edited by - LeighMarie on 05/02/2004 17:40:36
Response Posted - 05/02/2004 :  12:12:28  Show Profile
Hi Brooke,
Thanks for taking the time to share your sail research with us. I'm intrigued by the batten configuration. Have you seen any verbiage on this? I'd like to know more.
Brooke Willson
Response Posted - 05/02/2004 :  20:37:16  Show Profile
Steve, it was a compromise between the four full batten recommendations and the top batten full only. The idea is that it gives shape to the top of the sail but allows the bottom of the sail to be adjusted for draft.
Brooke
Edited by - Brooke Willson on 05/02/2004 20:37:45
osmepneo
Response Posted - 05/03/2004 :  06:15:50  Show Profile
Hey Brooke, it is good to hear form you. I for one appreciate your wisdom on this forum!
takokichi
Response Posted - 05/03/2004 :  10:00:19  Show Profile
Brooke -
Caveat - when catalinaowners.com started up, I was part of it. I am no longer connected to the company, and have no interest in it at this point, but thought I should point the conflict out -
Anyway, I bought a Doyle mainsail through the site, too. Mine was new is the summer of 2000 and is fully battened all the way down, but the details ought be similar if not identical. I love it. The construction is superb and after ~200 days of use, much in heavy air, it has held its shape and nothing has come loose.
The sail is cut very differently from the Catalina main that came with the boat and feels much more powerful. In winds over ~8 knots I can sail with mainsail only and tack reasonably effectively - although the boat is obviously going to be slow. With my old main the boat didn't point at all. We find that we sail the boat primarily off the main in most conditions. We'll reef the headsail down to ~100%, leave the full main up, and play the mainsheet like a dinghy with excellent power.
Anyway - I like mine :)
Response Posted - 05/03/2004 :  10:16:20  Show Profile
Brooke, if you use a Capri 25 mainsail on your tall rig C-25, that will raise the gooseneck slide (which is what you want to do), but it might be raised to the point that it will pop out of the kerf of the mast, either in normal use, or when reefing the mainsail. If you don't already have them, you should consider getting a set of mast gates to use with the new mainsail.
Response Posted - 05/03/2004 :  10:41:53  Show Profile
<br />Brooke, if you use a Capri 25 mainsail on your tall rig C-25, that will raise the gooseneck slide (which is what you want to do), but it might be raised to the point that it will pop out of the kerf of the mast, either in normal use, or when reefing the mainsail. If you don't already have them, you should consider getting a set of mast gates to use with the new mainsail.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I don't know if I would use mast gates to directly contain the gooseneck. The gooseneck should be either below or above the kerf opening.
Brooke Willson
Response Posted - 05/03/2004 :  14:44:36  Show Profile
Thank you Steve, I've thought of that. The gooseneck is safely below the slot in the kerf, restrained by a downhaul running to a cleat in the kerf below the boom. I also have a sail stop above the widened slot to keep the sail slugs from falling out. My understanding is that mast gates are primarily helpful if you have a boltrope luff.
Thank you, Don, for your kind words. Appreciation for my wisdom is not a good sign on your part.
Brooke
Response Posted - 05/03/2004 :  14:55:49  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">My understanding is that mast gates are primarily helpful if you have a boltrope luff.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Not so. I installed mast gates last year, and have sail slugs, and the gates are great! They keep the slugs from sliding out of the kerf when you reef the mainsail, and they allow you to flake the mainsail onto the boom much more neatly.
Response Posted - 05/03/2004 :  14:58:35  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Brooke Willson</i>
<br />...I also have a sail stop above the widened slot to keep the sail slugs from falling out. My understanding is that mast gates are primarily helpful if you have a boltrope luff.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
On the contrary, mast gates are primarily helpful with slugged sails.
Brooke Willson
Response Posted - 05/03/2004 :  17:17:12  Show Profile
I stand corrected.
Brooke
