I would like to obtain USCG documentation for my Catalina 25 (wing keel). The calculation requires the vessel's depth as defined by the CG:
"Overall Depth means the vertical distance taken at or near amidships from a line drawn horizontally through the uppermost edges of the skin (outside planking or plating) at the side of the hull (excluding the cap rail, trunks, cabins and deckhouses, and deck caps) to the outboard face of the bottom skin of the hull, excluding the keel. For a vessel that is designed for sailing where the interface between the “keel” and the “bottom skin of the hull” is not clearly defined (as is the case with an “integral” or “faired” keel), the keel is included in the “overall depth”.
I used the [url="http://www.uscg.mil/hq/msc/T3/cg5397/cg5397.form.htm"]USCG Interactive Application Simplified Measurement Form[/url] which in my interpretation, doesn't allow measurement of the deck structure in calculating the tonnage.
Don - just deleted my post so as not to confuse anyone. I found that form and used it while you were posting your post above.... Your right, we come in just a hair short
Thank you all for the quick response. Looks like a state registration is in order. I've just purchased her (an '83)and I am new to the Catalina 25. I'm looking forward to learning the boat and I am very glad to have found the forum. Thanks again for the info.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Catbird</i> <br />Thank you all for the quick response. Looks like a state registration is in order...<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
FYI...A "documented" vessel still needs to comply with state requirements, meaning if your state requires registration then you must do so even though your vessel is documented.
Catbird -- as in "sittin' in the catbird seat." The boat is being registered in Washington, DC. DC is one of the jurisdictions that forgives its (6%) sales tax on documented vessels. It was worth a try.
