 unwilling Princess
reuben
Initially Posted - 06/07/2004 :  15:44:02  Show Profile
I will risk redundancy to ask whether any of you have had this trouble with the Princess propane stove (factory installed in the 2000 WK): the tank is full, the valve is open, the ignitor clicks, there is a high whistling sound - not a gas hiss, but a treble wheeze - and nothing happens. No gas seems to be coming through the line. There is no gas smell, either. Any notion?
Reuben
C-250 WK #499
Bayfield, WI
Response Posted - 06/07/2004 :  17:55:35  Show Profile
Use a match... maybe the igniter is not doing the job. The match flame will also indicate if there is air or gas flow out of the burner.
Do you have a practical joker best friend... who may have filled the butane tank with fresh air?
reuben
Response Posted - 06/08/2004 :  09:03:51  Show Profile
Tried matches but nothing, alas. Neither air nor gas is coming through. Might be time to phone the former owner & ask what I'm doing wrong -- if I can catch him when he's not on his Islander 28.
Response Posted - 06/08/2004 :  09:58:54  Show Profile
The sound when you open the valve means that gas is escaping somewhere... if not at the burner, I'd look for a broken line between the valve and the burner.
