On the first real sail of the season my tiller snapped where the autohelm attached. It looked rotten. Can't believe we didn't catch this over the winter when we had more time. I'm in Ontario Canada -- where would be the closest place to purchase a new tiller. Is there such thing as a generic one? Regards, Dover
The factory-supplied tiller used on all Catalina 25's is made by a marine woodworking shop: H&L Marine Woodwork, Inc. 323-636-1718 . . . Fax: 323-636-1718 2965 E. Harcourt St., Rancho Dominguez, CA 90221
West Marine used to sell them, or you can get one from Catalina Direct: www.catalinadirect.com
I have used H & L Marine and they had the tiller in stock and had it in two days (order two) about $80 with the 2nd day. Just had to drill and install. Pyacht.com www.pyacht.net 222 Severn Avenue Annapolis, MD 21403 Toll free: 1-877-379-2248
I got mine at West Marine and it is generic. I can't for the life of me remember what other boats he rattled off as I looked in amazement when he had one... It was cheaper than I expected too, like $50US or so.
The drilling was super easy using the old one as a pattern.
Just put one on about a month ago from Catalina Direct. Cost about $56 and was here in 2 days. Was about 5 inches shorter and has about 2" more in the rise than the original which makes the knee clearance a lot better but a lot more personal when I'm standing and steering with the tiller between my legs! It's a beautiful piece of wood.
West Marine no long carries tillers. I tried to order one from them this past winter and was told that they didn't carry them anymore. Plus they aren't in the WM catalog. I ordered mine from Catalina Direct and recieved it in 2 days. As Charlie says, very pretty piece of wood.
Dover's experience is a good example of why, when you drill holes in wood (or wood-cored areas) in a marine environment, you should treat the inside of the holes. The ultimate is overdrilling, filling with epoxy, and redrilling. A simpler but reasonable approach is to drill and then run a pipe cleaner or some such thing soaked with varnish into the hole. Anything is better than nothing.
Dover's experience is a good example of why, when you drill holes in wood (or wood-cored areas) in a marine environment, you should treat the insides of the holes. The ultimate is overdrilling, filling with epoxy, and redrilling. A simpler but reasonable approach is to drill and then run a pipe cleaner or some such thing soaked with thinned varnish into the hole. Anything is better than nothing.
When mounting my replacement tiller 2 years ago, I used thin neoprene washers from Home Depot to prevent water from getting into the mounting bracket holes in the wooden tiller. Between the washers and the tiller cover, my tiller still looks brand spankin' new.
